Old 07-30-2015, 05:00 AM   #1
gtaylor318
gtaylor318's Avatar
Drives: 2013 Lt 2
Sea Foam
Is it ok to put Sea Foam in the gas tank of 2013 Camaro Lt 2?
gtaylor318 is offline   Reply With Quote
Old 07-30-2015, 05:18 AM   #2
Squishy
Squishy's Avatar
Drives: 2016 camaro 1SS
Why would you want to do that? Your cars still new shouldn't need to add sea foam unless you're having issues with the car. If it ain't broke don't fix it.
2016 BLK Camaro 1SS/LT1 M6:
NPP | black front/rear bowtie | Blacked out taillights
2011 IOM Camaro 1SS/RS LS3:
Stainless works 1 7/8" LT headers w/ Offroad pipes | TSP Cam 235/239 on a 112 | Powerbound 25% UD Pulley
Roto-Fab Cold Air Intake | SW Retro Chambered Catback Exhaust | VMax Ported TB | Hurst Short Throw Shifter
Trunnion upgrade | LSA Oil Pump | BMR 1.25 Spings | R1 Concept d/s Rotors
Tuned by Lashway Motorsports - 501 Hp 430 ft-lb
Squishy is offline   Reply With Quote
Old 07-30-2015, 05:24 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Sea foam rally won't help much in the gas tank as no fuel passes thru the intake manifold and over the valves, which is what mostly you need to have cleaned. You can spray the sea foam directly into the intake manifold. There are a couple good threads in this forum that cover this subject. The best thing to get for your direct injected engine is a catch can.
Old 07-30-2015, 05:35 AM   #4
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
Spray it into the manifold
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 07-30-2015, 08:50 AM   #5
kville988
Lurking in my SS
kville988's Avatar
Drives: '14 2SS/RS L99
CHECK THIS OUT https://youtu.be/u6UeJXkzDW8
kville988 is offline   Reply With Quote
Old 07-30-2015, 09:27 AM   #6
AITI
Drives: 2015 LFX Auto
Correct. I will add that we are seeing more failed catalytic converters, bent valves from the large chunks of the deposits breaking loose and getting trapped between the valve and seat, and piston and cylinder wall scouring when ANY solvent based upper induction cleaning service is used on a DI engine. Never was an issue with Port injection as the carbon build up was minor and somewhat soft where it is major on these DI engines and is very hard and brittle causing the scouring. In the gas tank, most all additives are not going to do a thing as the fuel never touches the valves, but be aware of the potential damage to your engine if you have more than 20k miles on it and did not run a good catchcan.
AITI is offline   Reply With Quote
Old 07-30-2015, 03:50 PM   #7
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
Originally Posted by kville988 View Post
Not impressed...
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 07-30-2015, 04:01 PM   #8
AITI
Originally Posted by PalmerGA View Post
Not impressed...
I'm with you. Now for a PI engine like the LS3 and L99, a solvent based upper induction cleaner can be used with little chance of damage to the engine as there is only a limited amount of soft carbon built up on the pistons and nothing generally on the valves.
Old 07-30-2015, 07:28 PM   #9
silverbullet415
silverbullet415's Avatar
Drives: 2018 Camaro ZL1 1LE
Seafoam is garbage
silverbullet415 is offline   Reply With Quote
Old 07-30-2015, 07:49 PM   #10
Banshee
Institutionally Insane
Banshee's Avatar
Drives: 2013 IOM 2SS/RS 1LE
Originally Posted by silverbullet415 View Post
Seafoam is garbage
Care to explain based on experience? Or is your comment baseless?
If you use top tier fuel, and change your fuel filter as recommended, there is no need for Seafoam for the oil, fuel or upper valvetrain (valves)
If you do a lot of stop and go driving, neglect oil changes, buy crappy gas, don't change fuel filter, don't change air filter, Seafoam will help.
Broad-stroked, a 2013 vehicle, used regularly, properly maintained, needs NO additives.
I use Seafoam in all my older vehicles (94 ZR2 and 03 Cavalier), 2 cycle equipment, tractor..I have been using it for 15-16 years. Stuff works great. Pay no attention to the inflammatory idiot who posted prior.
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas. What do you say, is it the new Bluesmobile or what?
Banshee is offline   Reply With Quote
Old 07-31-2015, 06:41 AM   #11
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
I Seafoam about 2 tanks before oil change. Car has almost 47K miles and is running fine. I also run an Elite Catch Can.
Scott@Bjorn3D is offline   Reply With Quote
Old 07-31-2015, 07:57 AM   #12
kville988
Lurking in my SS
kville988's Avatar
Not impressed...
I wasn't impressed either. Glad I didn't try it. That guy tries to debunk a lot of stuff. He has debunked most of those off the shelf additives, boosters, and what have you. Its a honda lol but it's something to go off of. If it does nothing for his honda it won't do anything for us.
Old 07-31-2015, 08:08 AM   #13
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I'd be more interested to see what it does on the valves. Carbon on pistons does not really affect performance. I suppose enough of it could create a hot spot.
I'd personally rather run a can of Seafoam or other upper intake cleaner every once in while than have a catch can just because I don't like crap hanging off my engine.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 07-31-2015, 10:04 AM   #14
AITI
I assume your referring to a port injected engine which it is fine to use, valves on port injected engine do not build any deposits due to the injectors constantly spraying them with detergent fuel. Now, if your talking a DI engine like the LLT or LFX then do NOT ever use it. In the gas tank does nothing as fuel never touches the valves. Using it as an upper induction cleaning can cause damage due to the severity of the coking build up on the valves . Break those big chunks loose and we see damaged catalytic converters, scoured pistons, and in rare cases a large chunk gets stuck between the valve and seat and if the piston hits the stuck open valve, bent valves. Really need to differentiate what type of fuel injection the engine has. And for 2016 and up all GM gasoline engines are now DI.
