Old 10-10-2015, 10:09 AM   #1
drew peacock
Banned
Drives: 2012 2SS INFERNO ORANGE
leaking around oil filter
yo lads.
2 weeks ago i changed my oil and filter..used an ac delco filter..
tightened it up half a turn
ok noticed today it's leaking...so removed the filter...checked and cleaned the gasket and tighened it 3/4 of a turn.
it's still weeping a little..
anyone have any ideas?
maybe a bad filter i think?
cheers drew
drew peacock is offline   Reply With Quote
Old 10-10-2015, 10:12 AM   #2
Swacer
Drives: 2018 GT350
I had a similar problem, I believe I overtightened the filter. Changed the oil and filter, all good now.
To save you from more frustrations, just change it.
Off to the Dark Side
Swacer is offline   Reply With Quote
Old 10-10-2015, 10:17 AM   #3
drew peacock
Banned
how tight exactly should it be?did u use ac delco?
first time i did it half a turn
Old 10-10-2015, 03:54 PM   #4
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Should be 1 turn. Sticker right on the filter says so.
I once had an STP filer that was leaking around the swaged over sheet metal bead, and had to replace it. I've never seen that on an AC Delco filter.
Make sure the mating surface on the engine is clean and that you oil the rubber gasket so that the filter can easily go a full turn.
Rock-It Man is offline   Reply With Quote
Old 10-10-2015, 06:08 PM   #5
GEN-IV
Right Cam
GEN-IV's Avatar
Drives: 2010 LS3 / 79 Z28
I put them on about 3/4 turn, hand tight, and no issues. It's probably a bad filter, nothing that you did, just pick up a new one and another quart of oil.
2010 2SS/RS M6 CGM E-Force + 2015 1LT V6/A6
GEN-IV is offline   Reply With Quote
Old 10-10-2015, 07:34 PM   #6
sdynak
Drives: 2010 1SS
Echo others.. not worth playing with.. just get a new one and replace for peace of mind. I did just put on a Mobil1 filter.. so far so good.
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
sdynak is offline   Reply With Quote
Old 10-10-2015, 07:39 PM   #7
BLK141SS
BLK141SS's Avatar
Drives: 2014 1SS M6 NPP
Make sure you don't have a double gasket. Sometimes the old gasket will stick to the filter flange on the engine block. After checking, clean the mounting flange and then the gasket on the filter and lightly oil it again. Hand tighten the filter, I put mine on fairly tight to be honest. If it leaks after this, then replace the filter.
BLK141SS is offline   Reply With Quote
Old 10-10-2015, 07:46 PM   #8
BigRed585Lbs
Drives: Sierra and Tahoe
Make sure you don't have one of the "E" suffix filters. They're not as good as the older PF46 filters.
Or get a NAPA Gold or Wix and worry no more.
What does Bobtheoilguy know anyway.
BigRed585Lbs is offline   Reply With Quote
Old 10-10-2015, 08:00 PM   #9
Nelly101
Nelly101's Avatar
Drives: 2013 Camaro 2SS 1LE
I had the same issue..I bought my Camaro back in June and put about 1500 miles on it and I noticed there were spots on the floor in my garage.I looked underneath and noticed oil on the filter..Shoot I have warranty on it so I took it to the dealership and the service guy told be it was a bad seal on the ac delco oil filter..Changed the filter and no more leak so far..but only put about 100 miles since replacement..it just sucks that I have to check after driving it..shouldn't have to...
Nelly101 is offline   Reply With Quote
Old 10-10-2015, 08:00 PM   #10
Rock-It Man
Originally Posted by BigRed585Lbs View Post
Make sure you don't have one of the "E" suffix filters. They're not as good as the older PF46 filters. Or PF63.
Or get a NAPA Gold and worry no more.
There's nothing wrong with the "E" filters.
Old 10-10-2015, 09:25 PM   #11
MrChrisLS3
Drives: 2018 1SS M6
This was my first thought, as I had exactly this situation on a previous car.
MrChrisLS3 is offline   Reply With Quote
Old 10-10-2015, 10:46 PM   #12
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
Was that the filter housing not the actual filter right? The filter has opened ends on both sides and sits in a housing.
lawman007 is offline   Reply With Quote
Old 10-10-2015, 11:09 PM   #13
drew peacock
Banned
cheers guys.
all mating surfaces are perfect.
will replace the filter..it didn't leak at first..only started a week after i fitted it..
Old 10-11-2015, 05:33 AM   #14
myold88
myold88's Avatar
I had a slight oil leak when my SS was under warranty. A Chevy dealer told me I had
2 filter gaskets from my last oil change. They fixed it at no charge.
My mechanic (indépendant/friend) told me 2 gaskets would leak large amounts
oil as the filter would not seal, and he knew he only put one gasket on my car.
Long story short, it was my oil pan gasket that was leaking all along, which was
also fixed by another Chevy dealer under warranty.
I still don't know if you can drive any distance with 2 oil filter gaskets without a very
large leak.
