Old 10-15-2015, 07:23 PM   #1
Dragonman
Dragonman's Avatar
Drives: 2015 1LT OBE
Wind noise from driver's side door
Wondering if anyone else has had an issue where they get wind noise from one side or the other.
It sounds like the window is cracked a hair or two but when I hit the button to raise, then lower and raise it doesn't affect the noise happening. I notice it the most when driving with a cross wind.
How far should the windows move when they "Index" as the door is opened?
_______-2015 1LT JUSTICE----------------------------------1997 B12-___________
Dragonman is offline   Reply With Quote
Old 11-08-2015, 07:44 PM   #2
Tonydig11
Drives: 2015 2ls bright yellow with strips
I hear that wind noise as well. My window indexes about an inch. Maybe a hair less
Tonydig11 is offline   Reply With Quote
Old 11-09-2015, 10:49 AM   #3
ryanyoung1768
Drives: 2013 Camaro 2LS
since Day One. Crosswinds give a bad whistle on the driver's side.
2013 2LS
T-Rex billet grille, CAI intake, Magnaflow mufflers, VMax ported throttle body, Elite Engineering catch can.
ryanyoung1768 is offline   Reply With Quote
Old 01-29-2016, 10:53 AM   #4
Dragonman
Dragonman's Avatar
I am cautiously optimistic. My dealer's Service Manager called this morning to report the technician was finally able to get the car to produce the noise reliably enough to track down where it's coming from. This is the third visit to the dealer for this issue. They've been back and forth with GM tech support on this without much help. From what I was told there is some kind of seal on the leading edge track that the tech was able to push on and make the noise stop. They are ordering the part and if all goes well it should be in Monday and I'll have my Camaro back that night, without the wind noise. If this part in fact fixes the issue a TSB may be generated for others experiencing this problem. When I get a copy of the work order I'll get the specifics posted here.
Old 01-29-2016, 11:04 AM   #5
Dragonman
Dragonman's Avatar
Also, maybe this thread should be moved over here; http://www.camaro5.com/forums/forumdisplay.php?f=70
