Old 10-19-2015, 08:08 PM   #1
chfakers13
Drives: 2015 Camaro SS/RS
With Cam, Headers and Clutch do I need to upgrade axels?
Next Monday my 2015 SS goes in for a Night Fury Cam, SW Headers, new clutch and dyno tune. Already have a CAI intake. Hoping to be around the 480 rwhp mark. Will the stock axels hold with drag radials or do I need to upgrade before going to the track? Thanks in advance for your advise.
chfakers13 is offline   Reply With Quote
Old 10-19-2015, 10:28 PM   #2
Bodywerks
Drives: 2015 2SS/RS/1LE
Shouldn't be a problem. Even the clutch is more than necessary, unless you plane to hit the drag strip every weekend. Guys are running 700-800+ on the stock clutch.
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 10-20-2015, 06:26 PM   #3
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
you should try a new toe and trailing arm combo though to limit wheel hop as it is what really causes a lot of havoc out back......
Old 10-20-2015, 07:47 PM   #4
Joseph1LE
Drives: 2015 Camaro SS 1LE, 2001 Camaro SS
+1^ I think your axles will be ok if you do a couple things to counter wheel hop.
2017 GMC Canyon All Terrain- daily driver/dirt bike hauler
2015 Camaro SS 1LE- sold
2001 Camaro SS SOM M6- sold
1999 Firebird Formula A4- sold
Joseph1LE is offline   Reply With Quote
Old 10-20-2015, 10:38 PM   #5
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I've ran multiple times at the track on stock axles. But I've been scared to really launch hard since the stock axles are so fragile. So I have shitty 60' times.
I just recently bought 1000hp DSS axles and they're on their way.
Gonna install those and now I can launch hard and not be so worried that I'll have to get towed home from the track..
So in summary, if you have the extra $1200, do it. It's good peace of mind and good for the long run.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is offline   Reply With Quote
Old 10-20-2015, 10:53 PM   #6
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
To be honest I'm more worried about breaking my diff than axles
Save the money on axles and look for a zl1 diff to swap in, they're bulletproof.
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-21-2015, 03:53 AM   #7
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Are you a manual or auto? Plenty of people have broken stock axles on stock power at the drag strip running manual cars. Autos seem to be no problem.
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 10-21-2015, 08:18 AM   #8
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
This.
If you're going to spend $1200 on axles, just keep saving and spend $2500 on a ZL1 driveline. No more worries.
There's a ZL1 rear cradle for sale in the ZL1 classified section FYI.
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap|
Built by J-Rod.
Taco Time is offline   Reply With Quote
Old 10-21-2015, 01:08 PM   #9
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
On a dead hook youll break an axle way before it gets to differential. Just do axles and a TruTrac and be done with it. More than enough for a cam only car.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 10-21-2015, 01:32 PM   #10
fif_gen_powa
Spend 2k+ and still have a weak diff. No thanks
Spend the money on a zl1 diff and really be done with it
8.3@164
Old 10-21-2015, 01:39 PM   #11
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Hes talking about a clutch, so hes a manual. Autos don't have the issue because the whole drivetrain is preloaded, its not snapping back there like it does when you dump the clutch in a manual.
Old 10-21-2015, 02:29 PM   #12
1KillerSS
1KillerSS's Avatar
Single dumbest thing, I have done today! Completely missed that, whats even worse, is I read through the whole thread twice looking for that answer.....
Build thread
Old 10-21-2015, 03:18 PM   #13
Ajdin@A2BMotorsport
Drives: 2013 Camaro 1SS/1LE
Slip the clutch, dont dump it and youll be fine. I have about 100 passes on my car with similar power, stock clutch + stock axles.
Aruns car has stock clutch and axles and has seen a bit of track time too with no issues, though it stinks like clutch after a couple passes, but thats due to slipping the clutch.
Ajdin@A2BMotorsport is offline   Reply With Quote
Old 10-21-2015, 06:17 PM   #14
christianchevell
And if your worried about things upgrade some things like the Diff with a LPW cover that is twice as thick to keep the diff stiff as its aluminum. Sticky tires can be a enemy and wheel hop and hard launches. But being smart and wanting good launches the rpms do not have to be as high even as the launch control in the car and be more in the 3500 range and that's the best info I have learned over time. Beef the rear and suspension and you should not trash it unless your trying to abuse it.
