03-08-2016, 10:08 AM | #1 |
Drives: 2010 camaro 2ss Join Date: Feb 2016
Installing CAI brand cold air intake
So I just got my CAI cold air intake installed. Haven't started the car up yet. Do I need to disconnect the battery for half an hour or so to reset the computer before I start it so i don't get a CEL? Or will the computer automatically readjust while its running for the first 10 mins or so?
03-08-2016, 10:10 AM | #2 |
battery should have been disconnected when you installed. at this point dont think it would matter, computer will adjust.
03-08-2016, 10:10 AM | #3 |
I solve problems for a living. Either accept my advice or go figure it out on your own.
03-08-2016, 10:36 AM | #4 |
USMC 1980-1990
Drives: 2010 Camaro 2SS/RS Join Date: Apr 2012
Whether you disconnect the battery or not the engine is still going to have to adjust to the new air flow. It will take a lot longer than 10 minutes to do this. Just drive the car normally for a while and don't do any full throttle pulls right away and it will be fine.
USMC 1980-1990
My other toys are Harleys |
03-08-2016, 10:48 AM | #5 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
There's no reason to disconnect the battery other than the manufacturer's lawyer tells them to say that. All you're doing is disconnecting the MAF which is off with IGN anyway. Installed the ones on my SS and ZL1 without doing that and didn't have a CEL or any other issues.
03-08-2016, 10:50 AM | #6 |
Yeah I don't need to disconnect the battery to install a CAI. Im not an idiot. I was just wondering if I should to help the computer reset after install beaus I have read where people do get a CEL afterwards.
03-08-2016, 11:22 AM | #7 |
get ready...the first time I started mine I could hear it sucking in air....throttle response was way better. love mine.
03-08-2016, 01:33 PM | #8 |
USMC 1980-1990
I did mine the same way you did and have never gotten a CEL.
USMC 1980-1990
03-08-2016, 03:27 PM | #9 |
Drives: 2014 Camaro 2LT Deep Magenta Join Date: Apr 2015
Yeah, I did mine didn't disconnect battery either..
03-22-2016, 05:23 PM | #10 |
Will adding a CAI void the factory warranty?
03-22-2016, 05:40 PM | #11 |
Drives: Dusk SE Join Date: Jun 2014
03-22-2016, 05:48 PM | #12 |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
Installed 2 without disconnecting the battery, no issues on either
2016 Hyper Blue 2SS |
03-22-2016, 06:15 PM | #13 |
Drives: 2010 2ss RS. White (RIP) 2012 LS3 Join Date: Sep 2011
03-22-2016, 06:16 PM | #14 |
I didn't disconnect my battery, either. but I didn't unplug the MAF sensor. I just unscrewed the sensor from the old airbox (still attached to the harness), set it aside, and installed the CAI. Bolted the sensor into the new intake and drove away happy.
A CAI is not going to void your warranty. It's one of the most-commonly installed aftermarket mods on any vehicle (not just Camaros). Dealers are used to seeing them and probably won't even say anything to you about it.
-Cameron Lashley
Albany, GA 2011 Camaro 2LT/RS 3.6L M6 Summit White w/silver rally stripes CAI intake, VTC, VMax PTB, VMax Iceolator, Apex intake scoop, Roto-Fab washer bottle relocate Build Journal: http://www.camaro5.com/forums/showthread.php?t=419992 . |
