04-13-2016, 08:05 AM | #1 |
Drives: Camaro SS 2SS Convertible Join Date: Mar 2015
Pulling Left
when launching my car it pulls hard to the left ,shouldn't traction control stop the car from pulling this hard . Should I heat up the tires more before a launch.
04-13-2016, 05:15 PM | #2 |
Drives: 2010 6.2L SS Join Date: Sep 2015
Maybe you're gripping the wheel too tight,
04-13-2016, 08:07 PM | #3 |
old school chevy rodder
Stock tires are not meant to be heated by burn out. Torque will make a vehicle want to crouch down on the right rear when the power is transferred , countering it is part of driving but so also is the need to modify the rear suspension to avoid wheel hop which can be damaging to axles, and if your car pulls to hard in one direction its not good.
Traction control just tries to help you grip, torque management will take power from the slipping wheel if not tuned out, and stabillitrac is there to save your butt if you start really going sideways by applying the brakes to help you steer straight. My car has so much torque it will loose traction and the right rear wants to go right but it counters from stabillitrac and my letting off the gas if I should happen to shift too high in the RPMS especially in the lower gears when going through the gears. The whole car can rock and you definitely get a feel for it.....getting fishy.
