Old 04-14-2016, 12:33 AM   #1
Wvbowhunter99
Drives: 2010 camaro ss
3.91 or motive 4.10
Hey guys I've been all over this forum searching reading staring at threads lol I can't decide on what gear to run I have a 2010 ss m6 currently tore apart.i have a Btr stage 4 cam to install looks headers borla cat back cai intake.i have the heads sent to advance inductions and sending intake out to rhino tomorrow!also have a nitrous outlet kit Gona run a 200 shot with a dedicated fuel system.Sorry for long post but I've been leaning toward 4.10 but afraid it might be to much.thanks for any input
Wvbowhunter99 is offline   Reply With Quote
Old 04-16-2016, 06:28 PM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
3.91s. Much better gear set than the 4.10. All the 4.10s I have heard were loud. 4.10s are also weaker than the 3.91s.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 04-16-2016, 10:24 PM   #3
Wvbowhunter99
Thanks for the reply I haven't heard any noise from the motives running around in 5th gens here but I'm afraid going from a 3.45 to 3.91 won't be a big difference.
Old 04-17-2016, 05:30 PM   #4
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
It is. Its definitely noticeable. Once you put the 3.91s on, it could be too much gear for a 200 shot. Depends on what you do with the car.
Old 04-17-2016, 08:15 PM   #5
blakjak55
drinks virgil's
blakjak55's Avatar
Drives: 2010 2SS M6
It's a big difference.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared
blakjak55 is offline   Reply With Quote
Old 04-17-2016, 10:27 PM   #6
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
Stay away from 4.10s. They are noisy. I have them and plan to lose them. Plus with what you are talking about doing its too much gear. Hooking will be a major problem. 3.91 at most. Might even think about 3.73.
Sent from my iPad using Tapatalk
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
Old 04-18-2016, 02:45 AM   #7
tbss1
More then meets the eye!
tbss1's Avatar
Drives: 2010 Camaro 2SS/RS 426 hp
It's funny, I have 4.10, and it has no noise, and I have all poly bushings on my suspension, which transfer more noise to the cabin then stock bushings. I have been down the 1/4 mile a few times, I also drive my car hard, with no problems. I've had them in my car for almost six year, I also use my car as a DD. I've herd that if you don't set up the gears right they make noise. I will be installing a LPW diff cover for add strength for the diff next week, I just got in the mail today.
2010 2SS/RS, M6, OBX 7/8" l/t headers, with high flow cats, MBRP full 3" exhaust, Whipple supercharger, 3.875 pulley, ID-1050X 1260CC injectors, JRE rough idle street blower cam kit, ZL1 fp, ZL1 fpcm, ZR1 3 bar map sensor, cold air intake, Richman 4.10 gears, BMR toe rods, trailing arms, f/r sway bars, f/r sway bar end links, BMR end link brackets, full BMR poly bushing including solid rear cradle bushings, BMR frame connectors and tunnel brace, f/r Hurst swaybar bushing brackets, Fluidamper, MGR shifter, and tune by Jannetty Racing.
tbss1 is offline   Reply With Quote
Old 04-18-2016, 12:33 PM   #8
tadams72
tadams72's Avatar
I'd say your the exception rather than the rule. I've got poly bushings and solid sub-frame mounts which certainly does not help. Setup on mine is spot on checked by me and separately by very reputable a local professional race gear shop. They are just noisy. Add in the fact OP is going H/C/I and a 200 shot and 4.10s will be worthless to him. They are fun on the street with lower power numbers but just plain difficult to drive when you make big power.
Old 04-18-2016, 10:50 PM   #9
tbss1
tbss1's Avatar
Don't know if you saw this, just thought you might want to read this, if you didn't see it yet.http://www.camaro5.com/forums/showth...richmond+gears
Old 04-19-2016, 01:05 PM   #10
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
Mine weren't noisy either, even with my poly bushings. Mine lasted for 60K miles before they broke (9K after supercharger was installed).
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 04-19-2016, 01:34 PM   #11
Motorboy8769
Drives: 2015 2ss
I haven't read anything about motive gear failures. Mostly just Richmond 4.10 before the 4.11 design.
Motorboy8769 is offline   Reply With Quote
Old 04-19-2016, 06:46 PM   #12
tbss1
tbss1's Avatar
jut read two posts of two 3.91 failing.
Old 04-19-2016, 08:45 PM   #13
260racin
Drives: 2011 2SS
I posted the 3.91 failure but I was at the track it was very sticky I left hard on drag radials but never made it past the tree. Tore it apart and it sheared roughly 10 teeth off the ring gear. I didn't side step the clutch just left it out hard and bam so I'm in the same boat right now I'm not sure what gear or manufacturer to buy? I liked the 3.91 but want the 4.11 to get to the torque curve faster. By the way car is n/a 505rwhp
260racin is offline   Reply With Quote
Old 04-19-2016, 09:53 PM   #14
Motorboy8769
Drives: 2015 2ss
What power level are most people seeing problems with gears in the factory 10bolt? Just trying to plan my build and wondering how soon the expensive back half will be coming..
