Old 05-23-2016, 09:12 PM   #1
Milkster495
Milkster
Milkster495's Avatar
Drives: Orange 2010 camaro 2ss
looking for bright fogs. to run as headlights
anyone know of a fog light bright enough to be used as headlights.? i just tinted my headlights and their so dark i can barely see my headlights through them
Milkster495 is offline   Reply With Quote
Old 05-23-2016, 11:49 PM   #2
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
Well after you crash because you cant see or you get pulled over at night, given a ticket and told you cannot move the car from the site of the pullover until that tint is removed, you may want to use headlights for headlights.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 05-24-2016, 10:04 AM   #3
kraut1971
BITCHN Camaro
kraut1971's Avatar
Drives: SOLD! Back in the looking zone...
This is what you want to order from Gen5DIY.com:
Item Number: 100350
Description: PSX26W 50 watt 5000k
Item Nubmer: 200050
Description: DRL Harness (Retains Daytime Function)
This combination allows me to run my halos (and/or headlamps) and DRL's at the same time. The 50W DRL's are so bright you can hardly tell the difference between only having the halos and DRL's or turning the headlamps on.
The color match of this bulb is identical to my headlamps & halo's but I never tinted my headlamps so you're on your own regarding the law.
(just ignore the rear-view of my Camaro - it was cropped together with the front view image above it).
BITCHN
kraut1971 is offline   Reply With Quote
Old 05-25-2016, 04:04 PM   #4
camaro2ss/rs
Drives: 2ss/rs
what headlights tint did you go with.. not sure why you would make them so dark that you could not see when driving at night.. i have headlight tint and its looks good and i can see at night
camaro2ss/rs is offline   Reply With Quote
Old 05-25-2016, 06:57 PM   #5
Milkster495
Milkster
I previously stated "tinted" but in all reality I paid a guy a autosport shop to paint them I'll try to upload a picture soon
Old 05-25-2016, 08:25 PM   #6
IBM
IBM's Avatar
Drives: '11 2LT/RS IBM
IBM is offline   Reply With Quote
Old 05-26-2016, 07:38 AM   #7
Ledzepx
Ledzepx's Avatar
Drives: 2010 2SS Camaro 6sp.
Originally Posted by IBM View Post
Headlights are to see and for on coming traffic to see you aswell. I would never tint or even paint my headlight. Your fog lights are there for a reason. Fog light
Ledzepx is offline   Reply With Quote
Old 05-26-2016, 10:35 AM   #8
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Your fogs will NEVER be bright enough to act as 'headlights'.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 05-26-2016, 01:13 PM   #9
BAD DAB
BAD DAB's Avatar
Thats just asking for trouble. What about passing state inspection?
Old 05-27-2016, 06:20 AM   #10
Ledzepx
Ledzepx's Avatar
No comment?
Old 05-27-2016, 07:09 AM   #11
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
I`m sorry OP but when I read you "paid a guy a autosport shop to paint them" I just started laughing that`s a first for me, I`ve never heard of anyone painting their headlights before!!!
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
