Old 05-24-2016, 08:07 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
P0650 code. MIL never has worked
Ok so from the day I bought the car I've never has a check engine light. I have a P0650 code for it. Has anyone ever found a fix for it?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 05-24-2016, 08:08 PM   #2
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
So that's a CEL for a faulty CEL? That's hilarious.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 05-24-2016, 09:36 PM   #3
MrChrisLS3
Drives: 2018 1SS M6
Soooo, is there actually a "check engine light" light?
MrChrisLS3 is offline   Reply With Quote
Old 05-24-2016, 09:59 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Been there with this one:
http://www.camaro5.com/forums/showth...385577&page=45
Was a fuse #15 IGN in the fuse box where I added a circuit...
-Don
747 RWHP 794 RWTQ
Old 01-05-2019, 06:18 PM   #5
Arkangel-77
Arkangel-77's Avatar
Drives: 2010 SS Camaro
was this what u were talking about? I just added a Halo always on harness to my Car and Now I am getting the same code? P0650
Originally Posted by hammdo View Post
Found the cause of the P0650!
Believe it or not, the MIL light is FUSED -- #15 5 AMP fuse in the engine bay fuse box... This is the SAME location where I had the Bosch intercooler pump. This is NOT in the wiring diagram nor does it show a 'fuse' inline for the circuit.
I DID verify the fuse was good (I even took the fuse out and check it with an OHM meter) and I check its voltage -- all showed good. I even pushed down ALL the fuses to make sure all were connected.
What I did this time, was I REPLACED the fuse with a new/fresh fuse. I then turned on the key and -- bam! The engine light came on with the key! The ONLY thing I changed was the 5 AMP fuse itself.
So, if you get this error CHECK the #15 5 AMP fuse FIRST in the engine bay fuse box! This IS the fuse that works the MIL circuit -- it could very likely have been a 'restriction' with low voltage or the fuse was the issue itself (appears to be this way)...
Yeah! So Ryan, I got it working...
-Don
Husband and Father
Arkangel-77 is offline   Reply With Quote
Old 01-05-2019, 06:22 PM   #6
hammdo
hammdo's Avatar
Ck your fuse #15. Put a new one in to be safe.
-Don
747 RWHP 794 RWTQ
Old 01-05-2019, 08:15 PM   #7
Arkangel-77
-Don
I will try - thank you for the info
Husband and Father
