05-27-2016, 07:09 PM | #1 |
Drives: 2011 camaro LS3 supercharger Join Date: Aug 2012
quick question belt slip and the new pulley from scol
i'm planning to get 3.4 pulley. just i need to make sure
did any one try the new (ZPE GripTec® 3.4" Magnuson TVS Pulley BLACK) from scol?any belt slip? as i know any pulley under 3.6 belt will slip.and need tensioner.
SLP TVS 2300,LS9 cam,ZL1 fuel bump, ADM FPCM,850ID,LT headers,CAI intake K&N, X pipe with stock exhaust Eibach 1inch suspension,Mantic Clutch 700HP, 91fule .8psi METH AEM, no timing up 557 RWHP
ZL1 black wheels,ZL1 front bumper, ground effects, |
05-28-2016, 10:42 AM | #2 | |
As you go down on pulley size your increasing torque to turn the blower which stretches the belt further under load. Think of the belt as an elastic band to some extent. Longer belt less tension. My supertensioner address both tension and length, our tensioner has a much stronger spring and is longer for more travel to take up more belt stretch. The JRE supertensioner fits Maggie, SLP, and Kenne Bell superchargers. Ted.
www.jannettyracing.com
05-30-2016, 06:23 AM | #3 | |
so what belt size fit 3.4 with supertensioner? FYI i have old style jackshaft SLP TVS2300 thank you
05-31-2016, 07:46 AM | #4 | |
2013-15 NAP-25-061000
06-01-2016, 01:57 PM | #5 |
i got one Super Tensioner today form JRE thank you ted
ZL1 black wheels,ZL1 front bumper, ground effects, Last edited by MS7; 06-02-2016 at 08:24 AM. |
06-01-2016, 01:59 PM | #6 |
Thank you sir.
06-28-2016, 10:36 AM | #7 |
Drives: Black 2018 Camaro ZL1 auto Join Date: Nov 2012
Just got mine Monday and installed it: Will post back the results......ty
2018 ZL1 A10 with PTB, ROTOFAB, Pulley and tune from
Vengeance. 607 rwhp/647 rwtq |
06-28-2016, 11:42 AM | #8 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Do yourself a favor and call left coast 32 for one of their LC32's double wrap pulley system brackets (just shy of three hundred bucks) to go with the JRE supertensioner, you will need a longer belt than listed for it, but it fixes the poor design on the jackshaft TVS which actually pulls the belt off of the blower pulley as the tensioner works decreasing belt wrap and increasing slip, their bracket replaces the stock front bracket and idler location on the TVS and reroutes the belt and tensioner layout which takes the old design which is like 40% to 50% wrap and gives you 70% to 80% wrap like the newer models, I still had belt slip with a 8 rib and 3.4 pulley until I added this setup, now I have zero.
06-29-2016, 01:42 PM | #9 |
Drives: 2SS/RS, supercharged LS3 Join Date: Jun 2013
Check out the tensioner that I have installed on my car. East Coast Supercharger manufactures this setup and they installed one on my car. Went to a eight rib belt as well. Running about 14.5 lbs of boost and no slip at all.
06-29-2016, 05:46 PM | #10 |
That's a sweet setup as well! 90-95% wrap looks like and it improves the crank belt wrap as well, I made my own bracket and added the lower pulley for better crank wrap.
06-30-2016, 09:48 AM | #11 |
Drives: 2011 Camaro SS Join Date: May 2014
Hey OP,
I have the same pulley 3.4" SCOL griptec pulley and the JRE tensioner. Usually no slip until the belt gets a good amount of miles on it (like 10k or so miles you will see a couple psi drop when going wot occasionally). Slap a new belt on it when it starts to slip and all is well.. |
06-30-2016, 11:26 AM | #12 |
Never seen a pulley like that: what is the advantage over a stock pulley?
01-17-2018, 02:37 PM | #13 | |
Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Sent from my SM-N950U using Tapatalk |
01-18-2018, 08:59 AM | #14 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
I don't see this kit on their site, only the standard tensioner setup. Am I missing sonething? Do you have a link?
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
