06-06-2016, 12:16 AM | #1 |
Drives: Black 2010 2ss Join Date: Jun 2015
Fly Cutting Pistons
Hey guys im looking to get a LG G6X3 cam and im having my heads ported by BO WHITE a couple months ago and he is holding on to them for me until he comes down on vacation for the 4th of july. I want to mill them down for more compression but ill have to fly cut the pistons from what im reading.
Has anyone done this? Where can i rent the cutting too? And is there anyone in North FL area the could help? Thanks Zach 2010 Camaro SS (LS3) Ported Heads, FAST 102, NW 102 TB, LG G6X3 Cam, Innovate ethanol guage for flex fuel (e85/e93) all waiting for install when i get back from this deployment. Last edited by zfrederick; 06-06-2016 at 09:21 AM. Reason: set up info |
06-06-2016, 06:39 AM | #2 |
Drives: 2010 2SS/RS Join Date: Jun 2009
Ls3 or l99?
06-06-2016, 09:16 AM | #3 |
06-06-2016, 11:22 AM | #4 |
I have l99 so can't give much help but can tell you that from what I've read the ls3 pistons don't have much room to cut into
06-06-2016, 11:28 AM | #5 |
the bottom end of the L99 and LS3 are the same. the only difference is the top end but thank you
the parts never end!!!!!
06-06-2016, 11:46 AM | #6 |
Drives: 2SS/RS L99 BLACK Join Date: Apr 2010
LS3 pistons are different than l99. You can buy fly cutters that are drill operated and center off of the valve guide. Check out Lindy tool co. They are not very expensive.
06-06-2016, 11:52 AM | #7 |
what is the difference between the l99 and ls3?
06-06-2016, 11:54 AM | #8 |
Valve reliefs VVT
06-06-2016, 11:56 AM | #9 |
Here's the one from Lindy I have.
06-06-2016, 12:23 PM | #10 |
Drives: 2010 SS Join Date: Jun 2015
I wouldnt waste the time. A slight bump in compression at the expense of having to flycut isnt worth it IMHO. all that headache and effort for 5-10hp.
06-06-2016, 12:28 PM | #11 |
It's the 5-10 HP for this and 5-10 for that and a few more from this that wins races.
06-06-2016, 12:43 PM | #12 |
CamaroFans.com
06-06-2016, 01:28 PM | #13 | |
06-06-2016, 01:53 PM | #14 |
CamaroFans.com
Two different engines. Less compression on the L99 and it has exhaust valve reliefs for variable valve timing so sometimes when fly cutting is required on an LS3 it is not with the L99
