#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 06-16-2016, 11:21 PM   #1
BadBillyJack
Drives: 2016 2SS Camaro
Exclamation NPP exhaust rattle now has a fix!!!
For those that keep complaining of your NPP rattle woes, and letting everyone know that NPP isn't worth it because of the rattles, there is NOW a fix for this concern.
Attached is a pdf of the page from service information.
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 06-16-2016, 11:22 PM   #2
BadBillyJack
reserved for future update.
Old 06-16-2016, 11:31 PM   #3
SpookShow'84
Bump in the night
SpookShow'84's Avatar
Drives: '84 Monte Carlo SS, '15 Optima
We've heard about this "fix". It doesn't address the problem from a engineering/manufacturing viewpoint before it goes on the car.
It seems about the same as slapping some bondo in a quarter panel and calling it repaired.
It may work for now but seems like a design problem has hasn't been properly corrected.
SpookShow'84 is offline   Reply With Quote
Old 06-17-2016, 01:29 AM   #4
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
I'd rather have a new exhaust. They want to glue my broken exhaust?
BradfordCamaro is offline   Reply With Quote
Old 06-17-2016, 05:19 AM   #5
DBNSSNH
DBNSSNH's Avatar
Drives: 2017 2SS, HyperBlue, NPP, M6
Thanks for posting. Still not sure why this hasn't been addressed through engineering/ redesign of said product. Like someone said seems like a "band aid"..and we all know those eventually fall off!
2017 2SS Hyper Blue, Black hash marks, Black front splitter, SEMA Lower Grille, Kalahari, M6, Black Chrome 5-Split Spoke, Red Calipers, GlowTie (black), Sunroof, NPP, NAV.
4/29/16-1100 | 5/28/16-3300 | 6/29/16-5000
5/3/16-2000 | 5/31/16-3400 | 7/8/16 -6000
5/4/16-3000 | 6/14/16-4200
5/9/16-TPW 6/6 | 6/15/16-4B00
5/25/16-3100 |6/16/16-4300
DBNSSNH is offline   Reply With Quote
Old 06-17-2016, 06:57 AM   #6
raptor5244
Drives: 2022 CT4-V Blackwing
I am not liking this fix one bit. We risk of messing up the valves even more if the tech accidentally gets epoxy in the wrong places. All this TSB did is tell us where the source of the rattle is coming from but the proposed fix is nuts. "Use a q-tip taped to a screwdriver..." Cmon. So, are all the new NPP exhausts coming off the line now having robots apply epoxy to a pin on the NPP valve? If not, then I want the newly design version of the NPP valve that has the proper size and clearance, etc. so it doesn't rattle.
2002 Corvette Z06 - Black - Sold
2013 Camaro SS 1LE - Black - M6 - Sold
2016 Camaro SS - Mosaic Black - A8 - Sold
2017 C7 Stingray - M7 Coupe - Sold
2019 C7 Grand Sport M7 Vert - Sold
2021 Camaro ZL1 - Black - A10 - Sold
2019 Tesla Model 3
2022 CT4-V Blackwing - M6
raptor5244 is offline   Reply With Quote
Old 06-17-2016, 07:39 AM   #7
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
This is why they normally don't want you to see the repair procedure. 90% of the people who have this issue either don't notice it, or when they take it to the dealer all they know is that it is fixed. I'm sure the future valves will be fixed, but it is much cheaper / easier to have a dealer do this than replace thousands of valves.
Lucely Engineered is offline   Reply With Quote
Old 06-17-2016, 08:06 AM   #8
suzook
Drives: camaro
This really is bullshit. Cmon GM! Wtf?
2016 2SS,A8,NAV,NPP,MAG Ride,Sunroof
Hyperblue/JetBlack
suzook is offline   Reply With Quote
Old 06-17-2016, 08:26 AM   #9
bballr4567
Drives: 2016 Camaro 1LT M6
Crap, I've JB welded things before and it's been stronger after. If it works, it works. Some of you guys are never happy. The only change that will happen on the line making this product is adding more glue when its being put together.
bballr4567 is offline   Reply With Quote
Old 06-17-2016, 08:30 AM   #10
6spdhyperblue
Drives: 6th gen
thank you for posting.
interesting the bulletin claims you can select different exhaust modes without the car running. My car doesn't do this. I wonder if a software update was released.
I'll just be happy if it works.
6spdhyperblue is offline   Reply With Quote
Old 06-17-2016, 10:13 AM   #11
JR91
Drives: Camaro 1SS
I found out the other day that you can select different exhaust modes with the car off. All you have to do is hold the engine start button for about 5-10 seconds and then your car will power on. You will now be able to adjust the exhaust in the settings. My NPP exhaust rattles too, so I just leave it in track or sport mode for now.
JR91 is offline   Reply With Quote
Old 06-17-2016, 10:19 AM   #12
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Thanks for posting, but come on GM; this really is not a fix but a temporary Band-Aid.
nancygrl is offline   Reply With Quote
Old 06-17-2016, 11:26 AM   #13
6spdhyperblue
Drives: 6th gen
other than crushing the metal on the ceramic pin, idk what they can do. you cant weld it.
i think this will fall under the powertrain warranty, so we have plenty of time to see if this will hold up
Old 06-17-2016, 11:59 AM   #14
BadBillyJack
Sorry for trying to help everyone out, didn't know you would be such Nannies about it still. Guess i'll keep my mouth shut on all the other common problems when a repair comes out, because it will still not be good enough.
