09-14-2016, 09:08 AM | #1 |
Planning stages...
Drives: 1995 Z28,2014 Ford Focus ST Join Date: Dec 2007
Accessory 6-piston brakes, heavier?
I noticed that the 6-piston accessory front brake package features rotors with aluminum hats. As an overall package, are they lighter or heavier than the standard SS front 4-piston setup?
I did search and didn't find anything. |
09-14-2016, 09:18 AM | #2 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
6 pistons with rotors are heavier. By how much? I have no idea. it didn't feel like much more, but it surely was.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
09-14-2016, 09:46 AM | #3 |
Planning stages...
Thanks!
09-14-2016, 11:12 AM | #4 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
The aluminum hat can save about 5lbs from the weight of the rotor, given the the upgraded rotor is bigger - I would say it's 2-3lbs lighter than the solid version. The 6 piston caliper is bigger, but it's machined/cast with a minimal amount of material around the internals compared to the flat and bulky 4 piston.
Overall I would guess the 6 piston setup to be a pound lighter or about the same weight. It's expensive, but it's definitely an upgrade. If someone throws them up on a scale, please post the info
09-17-2016, 07:16 PM | #5 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
