10-04-2016, 10:54 AM | #1 |
Drives: 2010 camaro ss Join Date: Jun 2010
Belt slip SLP tvs230p
Hey guys. Right now I'm at about 13psi with a 3.2 pulley . I'm thinking about going on higher boost but don't know if I will start getting belt slip . I have the innovators west 10% od harmonic balancer and it might be the jre or ECS pulley tensioner. Car made 600whp as is. As far as fuel goes I have 85lb injectors and adm dual pump. Stock cubes forged motor.
10-04-2016, 11:14 AM | #2 |
Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
Jackshaft or non-jackshaft?
10-04-2016, 11:38 AM | #3 |
New style. Non jackshaft
10-04-2016, 12:07 PM | #4 |
Banned
Stock cam and manifolds?
10-04-2016, 12:12 PM | #5 |
236/250/118 lsa .612/.612 of course headers no cats
10-04-2016, 12:18 PM | #6 |
Banned
Strange. I make 10psi. On the same pulley. BTR3. Catted LT
10-04-2016, 12:24 PM | #7 |
Banned
Oh. You have a UD wouldn't have guessed it would make that much a difference
10-04-2016, 12:25 PM | #8 |
Probably because of my crank pulley 10% od
10-04-2016, 06:12 PM | #9 |
Drives: Maggie blown LS3 vette Join Date: Aug 2009
Are you sure it's not slipping now? At 13psi with a healthy blower cam and bolt-ons, seems like it should show a little more power. Or is your compression ratio way less than stock?
10-04-2016, 06:37 PM | #10 |
Doesn't seem like it. Are you in the golden triangle old motorhead?
10-04-2016, 06:37 PM | #11 |
Todd
do you have your dyno sheet? we can take a look at that and see if its slipping
10-04-2016, 06:38 PM | #12 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
Im running the 2.8 pulley on JRE's super tensioner with no belt slip. 12psi. Lower compression on fully built motor. 675rwhp with JRE Blower Cam
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
10-04-2016, 06:39 PM | #13 |
700RWHP-650TQ
Before building the motor in august i was 13.4 psi on 3.0 pulley with the JRE tensioner and that was without a cam and i was putting down 602rwhp with torco.
10-04-2016, 06:43 PM | #14 |
I'm out in the rice fields just west of Houston. It's kinda hard to tell because it typically doesn't slip at lower rpm when you can stare at the gauge a little. Mine started slipping at 5500 rpm....just when you need to be more worried about keeping the dang thing between the ditches. It showed up really well when the dyno operator logged boost too.
