11-28-2016, 12:19 AM | #1 |
Question on header wrap or coatings
Ok so I'm putting turbos on my car. I honestly don't want to wrap the heads just because it makes everything a bitch to work on and hold's moisture.
My question is. Can i send my headers off to get coated to keep heat down over wrapping them? Also what is a good place to send my headers to, to get them coated.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
11-28-2016, 07:51 AM | #2 |
Drives: Black L99 2SS/RS Join Date: Mar 2014
Hell yeah, definitely get them suckers coated.
11-28-2016, 08:13 AM | #3 |
I'm sold on coated headers. When I had them on my GXP I could put my hands on them within minutes of cutting the engine off.
11-28-2016, 08:16 AM | #4 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
Jet-Hot is one...I would do both...ceramic coat header both inside and out...then instead of wrapping just create a jacket using thermal material and secure with metal zip...keeps engine bay temps down...peace out...
11-28-2016, 08:48 AM | #5 |
Drives: 2011 Camaro SS Join Date: Nov 2010
I had mine coated several months ago by Calico Coatings. Less than $300 not including shipping.
Here is the link: http://www.camaro5.com/forums/showthread.php?t=472184
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery |
11-28-2016, 12:07 PM | #6 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Coating is a great way to go if done by a company that knows what they are doing . From the looks of your pic , it looks like you need to remove the header to get the valve cover off . That could be a real pain in the ass.
OLD GUY FLYING FAST AND LOW
11-28-2016, 03:58 PM | #7 |
Drives: '10 Black/IOM Camaro SS/RS Join Date: Mar 2010
both are good, but coating wont help as much as wrap. Turbo parts are a lot hotter than headers
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
11-28-2016, 11:49 PM | #8 |
Never wrap headers on a street driven car. Moisture gets under there and with all
that heat it cooks the metal and the metal cracks and falls apart and there goes your header warranty.
Cai Intake, Pacesetter Ceramic Coated 1 7/8 Long Tube Headers and Legato axel back exhaust.
12-12-2016, 10:36 AM | #9 |
Drives: 2013 2SS 1LE Join Date: Mar 2015
coat the headers and use the header blankets with the stainless ties to hold the blankets in place!
"ah hell you can always make more money!" - dad
" its no fun going slow!" '13 2SS 1LE NAV, LT, CAI, Tune with 447RWHP before new lungs, Billy Boat exhaust 3" Fusion. |
12-12-2016, 10:43 AM | #10 |
Drives: 2011 2SS/RS Callaway Join Date: Feb 2014
Correct me if I'm wrong but i thought you couldn't have headers in a turbo car. It seems everyone uses their stock manifolds.
2011 Callaway SC572 2SS/RS, TVS 2300 Supercharger, 1-7/8" Kooks LT Headers, Fast 85# injectors, E85 Flex Fuel Conversion, Fore Twin Fuel Pumps, MGW flat stick short throw shifter, McLeod RXT twin disc clutch, Liberty Gears Tremec trans, DSS 1000 hp axles, Nitto NT555r drag radials, 10#'s of boost, 702 rwhp/ 697 torque, Recaro seat upgrade
12-12-2016, 10:47 AM | #11 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Maybe if they are cheap cheap header. I been wrapping them for a long time the one's on the 5th gen has been wrapped over 5 year no issues.
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
12-13-2016, 05:01 PM | #12 |
You can't use a typical bolt on NA style header on any of the good kits. That doesn't mean there isn't headers made that will work. There is plenty, but since stock manifolds have made 1600+rwhp it seems silly to put a part that cost $1000 and is less reliable.
Nick
Corvette Z06 -1200ish rwhp |
12-14-2016, 04:50 AM | #13 |
I just wrapped them
12-14-2016, 03:34 PM | #14 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
I would get them coated for sure. I would not wrap them..it traps heat and cooks the welds.
