#Camaro6
AWE Tuning
Old 05-28-2017, 07:46 PM   #1
FringBirdAloha
Drives: Pre-production ZL1 M6
Why our rotors aren't cross drilled or slotted
Why are the Corvette rotors cross drilled/slotted and ours aren't?
FringBirdAloha is offline   Reply With Quote
Old 05-28-2017, 07:48 PM   #2
catdog
Drives: 2017 Camaro ZL1 M6 pdr roof CF blk
Cause those are gimmicks... for the most part...
If the ZL1-LE doesn't need them after extensive testing, then regular ZL1 sure doesn't...
catdog is offline   Reply With Quote
Old 05-28-2017, 07:49 PM   #3
FringBirdAloha
Smile
Agreed.
Old 05-28-2017, 07:59 PM   #4
Battlezone580
Battlezone580's Avatar
Drives: 2018 ZL1 1LE, 1969 Nova SS 396
Great point, however it would still add a aggressive look to the car.
18 ZL1 1LE|M6|Nav|PDR|CF Hood|CF WING|CF Dash|Tow Hook|
Battlezone580 is offline   Reply With Quote
Old 05-28-2017, 08:39 PM   #5
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
The red calipers are what I'm missing. Anybody got ideas for that?
mdmoore23 is offline   Reply With Quote
Old 05-28-2017, 08:40 PM   #6
Rooster OG
Rooster OG's Avatar
Drives: 2016
Powder coat would be my first recommendation, painting second.
Rooster OG is offline   Reply With Quote
Old 05-28-2017, 08:49 PM   #7
mr965
mr965's Avatar
Drives: ///M3
Red calipers for me too!
mr965 is offline   Reply With Quote
Old 05-28-2017, 09:12 PM   #8
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
I gotta have 'em.
Old 05-28-2017, 09:44 PM   #9
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
Drilled and slotted disks do provide a margin of stopping power. The scraping of the pads will shorten stopping distance maybe 4+ feet shorter. But it will shorten pad life.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 05-28-2017, 10:14 PM   #10
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
Here's the GT4R Black Dog Camaro....Slotted only...
For a track "upgrade", if you think one is necessary, usually slotted is preferred over drilled and slotted....Drilled rotors provide an easy path between holes for cracks, warping and possible rotor failure...Any heat dissipation gained from drilled holes is not worth the risk, and slotted is enough to add for some heat dissipation and improved braking....At least that has been my experience. Without spending a fortune, I went with slotted and a pad upgrade, and brake fade has not reoccurred...Definitely stay away from cheap drilled rotors....They may last forever on the street, if you want to get them for the look...
For the ZL1, you may not need anything....Not sure if anything is even available...yet. If you experience brake fade on a track day, I would suggest consulting a reputable aftermarket supplier...
Good luck.
90503 is offline   Reply With Quote
Old 05-29-2017, 10:55 AM   #11
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
On the corvette forum, we have used Mike for at least 10 years.
http://thepowdercoater.com/
speedraider is offline   Reply With Quote
Old 05-29-2017, 11:41 AM   #12
mdmoore23
mdmoore23's Avatar
Drives: 2017 ZL1
Dang. Looks like he isn't accepting any new customers right now.
Old 05-29-2017, 12:31 PM   #13
speedraider
Can't hurt to call him and ask. He is a really nice guy.
Old 05-29-2017, 06:12 PM   #14
TheRedhead
TheRedhead's Avatar
Drives: 2018 Red Hot ZL1 1LE
It's specifically for cooling.
It does, however, make for a more delicate rotor, unless you go with carbon ceramic. That would, however, drive the price up another 5-7 thousand.
So...then there's the Vette...
TheRedhead is offline   Reply With Quote
