07-20-2017, 07:08 AM | #1 |
Drives: 1968 Camaro, 2012 ZL1 Join Date: Nov 2011
Thinking of an intercooler
I am going to have to remove the nose of my ZL-1 to replace a headlight ballast shortly and I was thinking of upgrading my intercooler and adding an intercooler reservoir while I am there. My mods are 10% OD pulley, long tubes, cold air injectors and tune. I am also thinking of upgrading to an 18% OD. I forgot to add I do have larger injectors.
Question #1: with my current mods, is the upgraded intercooler worth the money and effort? Under what conditions will it help me? Question #1A: same question as 1 but with the 18% OD Question #2: If it is worth it, who makes the best value setup. Last edited by ZL1 TIBS; 07-21-2017 at 07:12 AM. Reason: omitted info |
07-21-2017, 12:07 AM | #2 |
"BEASTM*DE"
Are you racing it??? If not you can run 18pct pulley with your current cooler... However, the argument will be if you need larger injectors and a BAP...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
07-21-2017, 01:52 AM | #3 |
KaBoom1701
Only if you track your car...
Mods:
07-21-2017, 07:11 AM | #4 |
I do try to take it to the strip once or twice a year. It sounds like it is not worth the expense. I guess the days I do drag race, just spend some cool down time between runs?
I still like the idea of the expansion tank. What do you guys think of that? |
07-21-2017, 10:04 AM | #5 |
Drives: 2015 ZL1 Blue Velvet Metallic Join Date: Mar 2015
Tanks is way cheaper, allows for extra volume to provide longer periods of cooler fluid, makes changing fluid easier and should provide better IATs during your drag runs.
Roto-Fab CAI, ARH LT, SW 3" catback, JRE tune, Elite-2 CC, VMAX TB, Big Gulp, WW II relo, Lingenfelter S/C reservoir
07-21-2017, 11:05 AM | #6 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
...and allows for self-purging of air.
07-21-2017, 01:42 PM | #7 |
Drives: Black M6 2013 Join Date: Dec 2012
You have My permission to get a HX.
07-22-2017, 12:34 AM | #8 |
"BEASTM*DE"
+1...
07-25-2017, 07:17 AM | #9 |
Thanks for the input guys.
07-25-2017, 08:33 AM | #10 |
Banned
Drives: Camaro Join Date: Mar 2013
I highly recommend the Ron Davis HX and a bigger reservoir. I will hold my opinion on the Roto-fab reservoir until my current issues with them are worked out.
