#Camaro6
Go Back   CAMARO6 > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
BeckyD @ James Martin Chevy
Old 09-17-2017, 05:58 PM   #1
Lfsabch
Drives: 2018 Camaro1ls
What to expect from 2018s......
this is the fitments alot are coming with incase you are thinking of ordering a 2018
i went to dealer and only 1 out of the 5 camaros on the lot had perfect lines, the rest had the issues mine has.
so much for a quality car at premium price....
all issues on the passenger side, driver sides are perfect
Lfsabch is offline   Reply With Quote
Old 09-17-2017, 07:10 PM   #2
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
You would think after 3rd year of production they would be flawless
CruzySS is offline   Reply With Quote
Old 09-17-2017, 08:39 PM   #3
T Rex
T Rex's Avatar
Drives: '17 Hyper Blue RS, NPP, 6MT
That's very unfortunate...3rd year, c'mon GM!
T Rex is offline   Reply With Quote
Old 09-17-2017, 10:04 PM   #4
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Strange... My 16 doesnt have any of these issues...
soloknight6 is offline   Reply With Quote
Old 09-17-2017, 10:09 PM   #5
camaro5's Avatar
Drives: X-15 Velocipede
Yes. Buying off a large lot (200+ Camaros in stock) I would apply my personal checklist.
Ordering one means waiting 6 - 8 weeks to see where the wheel of quality landed for your unit.
That being said, I did this for my C6 (but ordered it) and it came through flawless in every way.
You never know what you're going to get.
Camaro Known Product Failures
Defroster vents leaking cold air onto windshield in A/C mode, causing condensation build up on outside of windshield after some time with A/C on
Front fascia – color match to body.
Fascia fitment to hood (gap and level, flush hood to fascia)
Fascia fitment to fenders
Paint defects – Blemishes, debris, dirt, scratches, and thin coverage
Paint thin or missing in door jambs, under hood, wheels, etc
Headliner does not fit properly - gap above the passenger side window
Wind noise leaks – some outside rearview mirrors “whistle” at 40 mph or above
NPP exhaust butterflies – for rattles when running, and butterflies closed
Door rattles from speaker bass – plugs, connectors, etc. inside door rattle
Squeaks or rattles over bumpy surface
Missing trunk light
A/C recirculation door sticks, pops – recirculation door hits body opening (I think they finally corrected this)
Differential noise when cold and turning
Coolant leaks at full operating temp
Fluid leaks from engine, trans, cooler lines
Steering wheel centered
No waxing or any buffing – wash only
To go further, print a copy of the dealer pre delivery inspection checklist and do it yourself
GM pays 1.5 hrs for PDI. It takes that long to find the unit, remove the plastic, and check all those boxes on the list.
If it isn't really obvious - out the door.
doc below
Or, buy a top-quality Camry or Optima - and feel your soul melt away mile after mile...blah
They are not expected to fix anything that's simply poor quality control in 2018, or 2019, or 2020, 2021 - omg gen 7.
They have eyes, they know what's going out the door.
Somebody looks at the poorly fitted headliners and says F it, because their manager told them to.
The manager said that because his boss told him to get them out, fast.
Asian manufacturers send back poor quality parts. Some things never change.
File Type: pdf Camaro Quality Pre-Delivery Inspection.pdf (54.2 KB, 319 views)
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 09-18-2017, 01:45 PM   #6
MuhThugga
Poppycock
Drives: Pontiac GTO
Tried to test drive an SS the other day. The dealer only had two in stock. The first one had the power steering fail while the car was idling in the lot. The second had a check engine light pop up and the salesman ended the test drive by having me park it in the service bay.
Quality.
MuhThugga is offline   Reply With Quote
Old 09-18-2017, 03:38 PM   #7
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
Drives: 2017 Chevrolet Camaro SS 1LE
I've never seen one like in the first pic, and I've seen many 6th gens...mine has very good body panel fitment.
SS 1LE is offline   Reply With Quote
Old 09-18-2017, 04:07 PM   #8
camaro5's Avatar
Quality.
This is their crappy steering torque sensor design.
Here I thought it was getting trashed by water and road salt, etc.
Nope. Brand new one on the lot. BS!
They just keep shipping them out - aholes
Don't worry GM, it's only our F'ing steering control
But it saves .05 mpg! Times their total production - it adds up
Holy sh!t! The Camry and Optima are looking better and better...
The closest I came to an alternative that wouldn't make me sick (camry, optima, etc), when I drove it was this:
Made with top quality - Concierge service dept. - 400hp - 0-60 4.1 sec - RWD -- twin turbos cast right into the heads to eliminate turbo lag...
2018 Infiniti Q60 Red Sport 400
But, it doesn't make you cream your pants when you start it up....I like to...
$60k
STANDARD DISCLAIMER
Old 09-19-2017, 08:08 AM   #9
MuhThugga
Poppycock
Drives: Pontiac GTO
Yeah, I wasn't impressed, and the power steering issue spans to other models, as well. My friend has a 2016 SS and he is having the same issue. His crapped out on a 600 mile drive back from Maine. Mind you, he had taken it in before and the dealer simply told him there was no fix and to restart the car if it happened again. They also refused to provide a loaner while they looked at his car.
And GM wonders why people don't think their shit is worth the price they are asking.
Old 09-19-2017, 10:52 AM   #10
nascarazy
nascarazy's Avatar
Drives: '18 ZL1 & '17 2500HD Midnight Ed
Lots of good info here... Thanks for the pre-delivery checklist. Just one more list I'll be going through when the new car arrives hopefully within a week.
2018 Camaro ZL1 - Garnet Red Tintcoat[/B]
- Order Placed@ dealership 8/12/2017
- 1100 8/21/2017
- 3100 8/23/2017 (TPW 9/11)
- 3400 8/25/2017
- 4300 9/11/2017 (VIN available)
- 4200 9/15/2017
- 4200 9/20/2017 (on train near North Platte, NE)
- 4200 9/22/2017
- 4200 9/23/2017 (car in town)
- 5000 9/25/2017
- 6000 9/26/2017 (Finally in our garage!)
nascarazy is offline   Reply With Quote
Old 09-19-2017, 03:51 PM   #11
camaro5's Avatar
The steering issue actually spans ALL their models and brands. Google it. omg
We have a forum member who had it crap out at 122mph in a curve. Class action is coming.
Thank you, and remember - It's not your car until the rear tires roll over the dealership's property line.
If a unit has too many problems, it's their car even if EVERYTHING is signed, dotted, charged, or the unit was ordered for you.
(reformed sales weasel giving back)
We used to cheer the customer off the property.
"Come on baby, keep going, keep going, don't even think about putting it in reverse and backing up
Front wheels...
Back wheels over the curb -
Down the road, burnin' gas.!!!"
Victory, I can eat for another day.
Every unit sold, entire sales staff.
STANDARD DISCLAIMER
Old 09-20-2017, 03:07 PM   #12
SpookShow'84
Bump in the night
SpookShow'84's Avatar
Drives: '84 Monte Carlo SS, '15 Optima
tagged
SpookShow'84 is offline   Reply With Quote
Old 09-21-2017, 12:50 AM   #13
Lfsabch
I too went in with a game plan but when i saw the car it all went out the window, definitely take your time with it and go over everything
this was the newest discovery and now its time to send it back into the shop to fix all the things GM fkt up with and have the magyver things to a normal standard... so much for my 8 week wait and get a car... love how no hiccups on me giving them the money but im expected to "deal" with all this.... gotta be some way to fall back on a crappy product and protect buyers
the back window line is center and straight.. antenna not so much
Old 09-21-2017, 01:18 PM   #14
Midnight Rat
Midnight Rat's Avatar
Drives: SS 1LE
Makes no sense how a car can leave the factory with a antenna off center.
Midnight Rat is offline   Reply With Quote
