Old 09-19-2017, 01:08 AM   #1
krisprz2010camaross
krisprz2010camaross's Avatar
Drives: 2010 Camaro 2ss/Rs Transformers
160 thermostat upgrade worth it?
Have been thinking about changing my stock thermostat or for a 160 one. Right now my car doesn't run hot. I have a 3600 stall, a trans cooler, and full bolt ons on E85, with 3.91 gears as well. I do like to drive my car hard sometimes and I see the temp rise a little bit, but nothing to worry about. If I change or the thermostat would that hurt or help my car? Would a retune need to be made? I've heard some people even say it adds power. Not sure if that's completely true.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage
LS3 conversion
Vararam intake(tune model)
Kooks LT headers & cats delete
Corsa ZL1 3" exhaust
RedBarn Racing Tune
CMS Stage 3 Cam
AFR CNC ported heads
MSD Spark plug wires
LNC-2000 Launch controller
NGK TR6 Spark Plugs
1le strut tower brace-TPIS spacers
Nick Williams 102mm throttle body
Fast lsxr 102 intake manifold
Slp 25% UDP
Katech Tensioner Pulley
Circle D 3600-3700 multi disk Stall
GM 3.91 gears
DDS carbon fiber driveshaft
ZL1 fuel pump & injectors
Flex fuel sensor(91/E85)
https://wheelwell.com/kris-perez
krisprz2010camaross is offline   Reply With Quote
Old 09-19-2017, 09:44 AM   #2
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Search a little and you will find that you will NOT get a definitive answer to this question........It seems to be one of the great mysteries of the automotive performance world. Adding power, no...possible cooling effects, who really knows. If your temps are bothering you, I would opt for an upgraded radiator.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 09-19-2017, 10:01 AM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
In warmer climates we usually say it's good for cheap insurance to keep your temps down but it's not really going to change much.
Juiced1 is offline   Reply With Quote
Old 09-19-2017, 10:37 AM   #4
saluki
Drives: 2017 Silverado
^This
You may have just started a multi page argument on accident.
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 09-19-2017, 10:49 AM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
http://www.camaro5.com/forums/showthread.php?t=505083
Interesting read.
Orange Krush II
Old 09-19-2017, 11:36 AM   #6
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
IMHO the factory T stat is your best bet .
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-20-2017, 01:52 AM   #7
krisprz2010camaross
I was thinking the same. I see up and down reviews from people saying it's worth it and other saying it's not and the stock one is the best. As for the upgrading the radiator I can't find one that will fit with my vararam intake. I'm also planing on changing the radiator hoses out for mishimoto silicone hoses
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-20-2017, 01:59 AM   #8
krisprz2010camaross
Originally Posted by olblue75 View Post
Very helpful. I was thinking about the mishimoto thermostat, but my cousin who works at a performance shop says that the cars they have installed radiators, fans, thermostats from mishimoto always break and then it takes over a month to get in contact with them to get a replacement. He said hoses are fine. Their thermostat would be a perfect in between. I might go with the slp 160
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-20-2017, 06:21 AM   #9
hammdo
'It's an experiment'
hammdo's Avatar
As far as mishimoto, they have been excellent with customer service. I can personally vouch for their speedy response when I had an issue with their oil cooler (I have an FI setup).
The lower temp tstat will open sooner sure, but once the engine gets hot, it's hot -- when ambient temps are warmer. When ambient temps are cooler (< say 70), you'll see engine coolant temps get closer to the tstat rating. In the 50s, I've occasionally scene engine coolant temps 168-170 on the freeway. I have an SLP 160...
-Don
747 RWHP 794 RWTQ
Old 09-20-2017, 09:07 AM   #10
xc_SS/RS
Drives: 2010 Camaro SS/RS
http://www.camaro5.com/forums/showthread.php?t=376093
it should work with the Mishimoto radiator according to this thread
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 09-20-2017, 09:00 PM   #11
krisprz2010camaross
That's interesting because phastek performance told me it wouldn't. That would be awesome if it does then I could do everything at once
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-20-2017, 09:04 PM   #12
krisprz2010camaross
-Don
I was thinking about the slp 160 but thought it would be too much of a change from the stock one and could throw a code? But I might end up going that route. My cousin told me that at his shop whenever they install mishimoto parts the customer always comes back and they have to replace it or fix something. I've never had a bad experience with their customer service. They answered my question about the oil cooler fast. I'll get the radiator hoses from them for sure.
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
Old 09-20-2017, 09:30 PM   #13
hammdo
hammdo's Avatar
I have their hoses also...
160 and no codes for me but, I'm not stock by a long shot 'o)...
-Don
747 RWHP 794 RWTQ
Old 09-20-2017, 11:08 PM   #14
krisprz2010camaross
-Don
That's good to hear i'll go with slp then
LS3 conversion
RedBarn Racing Tune
CMS Stage 3 Cam
NGK TR6 Spark Plugs
Slp 25% UDP
GM 3.91 gears
