Old 10-29-2017, 09:39 PM   #1
rjs1le
Drives: 2014 2ss/rs/1le
drilled rotors
Wondering if anyone has changed to a drilled or slotted rotor?
rjs1le is offline   Reply With Quote
Old 10-29-2017, 10:02 PM   #2
King Nothing
Under a Peterbilt
Drives: Rogue, Durango and Camaro
Slotted=good for track
Drilled=good for street and car shows
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 10-29-2017, 10:49 PM   #3
rjs1le
I see where others are asking about different types of pads, was wondering if anyone had tried a different rotor, if they are running on the track.
Old 10-29-2017, 11:36 PM   #4
King Nothing
Under a Peterbilt
A drilled rotor runs the risk of breaking apart from heat on the track. The holes hurt the function of the rotor itself. I have drilled and slotted rotors on my car, but I don't track the car at all. A DBA slotted rotor would be your best best.
M6 1 of 475
353rwhp 353rwtq
Old 10-30-2017, 07:46 AM   #5
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
R1 Concepts Premier Slotted. Track the car from time to time, so wanted to stay away from drilled or drilled/slotted. Running OEM pads right now, see no reason to change yet.
I would have expected this to be an easy searchable subject in the Wheel/Brakes/Suspension section.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 10-30-2017, 12:54 PM   #6
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
Slotted or blanks for the track. I've used the factory rotors for 2 years with Wilwood ProMatrix pads for track duty without issues. Went with slotted StopTech rotors for the front this year, with blanks on the rear. Ran GLoc pads front and rear and was basically all track duty. Warped the front rotors pretty hard at NCM during the Optima Search for the Ultimate Street Car event only because of another car catching fire at the top of a hill and we were stuck on the hill from it. Otherwise the rotors were just fine and no issues with them or the pads from the track duty. As stated, keep the drilled rotors for the car shows and street.
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 10-30-2017, 09:27 PM   #7
rjs1le
And now I know! Thanks for the info everyone.
Old 10-31-2017, 08:37 AM   #8
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I got recommended these by a garage at the track:
Gyrodisc. Good reputation apparently and the rotors are lighter than stock. Slotted, not drilled.
I ended up doing the CTS-V upgrade. Had to replace my front hubs too, the right was completely done at 40K miles + track use. I replaced with ZL1/1LE/CTS-V spec SKF hubs.
2020 ZL1 1LE [Moroso SC Expansion Tank, otherwise stock]
wakespeak is offline   Reply With Quote
Old 12-02-2017, 09:19 PM   #9
49North1LE
Drives: 2015 2SS/RS 1LE G7C,
I went with Baer Decela Sports front & back. Wanted improved looks at the lowest end of the cost scale, any braking improvements a bonus. DIY install with a buddy was a piece of cake.
49North1LE is offline   Reply With Quote
Old 12-08-2017, 10:06 PM   #10
BAD DAB
BAD DAB's Avatar
What about dimpled rotors for track use?
Old 12-09-2017, 09:01 PM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
We use OEM rotors and G-LOC or CobaltFriction pads.
Old 12-24-2017, 03:55 PM   #12
rjs1le
One more question on brakes. Had the wheels off doing some cleaning and notice four little steel casters on each front brake caliper. What are they and what do they do? Thanks
Old 12-24-2017, 03:57 PM   #13
imaSSnake
'Maro
imaSSnake's Avatar
Drives: 2015 SS 6.2L Auto 2SS
They are referred to as roller skates and I believe their only purpose is to combat brake noise
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
imaSSnake is offline   Reply With Quote
Old 12-24-2017, 05:57 PM   #14
rjs1le
Looks like a lot for brake noise, but ok ill go with it. Thanks for the info, Merry Christmas
