Old 11-24-2017, 07:36 PM   #1
RandyT
RandyT's Avatar
Drives: 2014 ZL1 Summit White
Tow hook
I am looking at adding a front tow hook on my 14 ZL1, I see there are quite a few companies that sell them.
Is it lots of drilling to install one?
Which is the hook most of you are getting?
RandyT is offline   Reply With Quote
Old 11-24-2017, 10:52 PM   #2
ZL1 FOR ME
Formerly RJT2SSRS
Drives: 2013 ZL1
Randy T ZL1 Addons has a decent tow hook kit. Put one on the front of my 13 ZL1 and was pretty easy. Go to their web site and take a look at the install instructions. Good luck with your project.
ZL1 FOR ME is offline   Reply With Quote
Old 11-25-2017, 11:06 AM   #3
Olddudesrule
Resident nomad
Olddudesrule's Avatar
Drives: 2014 Summit White 1SS/1LE
Same here. Used ZL1 Add On's tow hook for the front, and it was straight forward. Just had to drill one hole (well, pilot and full) behind the removable plastic cover on the passenger side of the bumper, and then bolt the tow hook receiver on.
Sold:
2007 Z06
2002 Viper GTS/ACR
2003 Z06
1965 FFR Cobra
2012 Nissan 370Z
ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing.
Olddudesrule is offline   Reply With Quote
Old 11-25-2017, 04:21 PM   #4
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
I believe Skylane765 has some.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 11-27-2017, 07:28 PM   #5
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Install Instructions
Do you have a link to instructions?
Orange Krush II
Old 11-27-2017, 07:58 PM   #6
ZL1 FOR ME
Formerly RJT2SSRS
Drives: 2013 ZL1
olblue75 I went to the web site but did not find th instructions. I will look in garage tomorrow. May still have them.
Did you try youtube for install video? May also be in the DIY thread.
Old 11-28-2017, 09:35 AM   #7
GONMAD510
Drives: 2013 ZL1 M6
Super easy to install. They include good instructions with a template on where to drill the hole. I didn't see any instructions on their site.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 12-04-2017, 11:37 PM   #8
Todd@LeftCoast32
Todd@LeftCoast32's Avatar
Drives: Shop Foreman
Check out are new crash bumpers designed to work with ZL1 addons tow hooks http://www.camaro5.com/forums/showthread.php?t=514715
Todd@LeftCoast32 is offline   Reply With Quote
Old 12-18-2017, 01:58 PM   #9
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
we make the tow hook for all the 5th 6th gen Camaro's we install free www.zl1addons.com
Skylane765 is offline   Reply With Quote
