12-08-2017, 08:55 AM | #1 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
Does Seafoam through the brake booster work on D.I. cars?
I've been wondering this. Can I use Seafoam through the brake booster on my 17 Camaro 3.6L? I don't "think" I need to yet but if it ever came to past that I did, would it work?
12-08-2017, 08:56 AM | #2 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Where did you hear to use seafoam with brakes?
12-08-2017, 09:03 AM | #3 |
The Brake Booster line is the vacuum line behind the intake that goes to the Brake Booster, it creates a vacuum which assists your braking, but the line can also be used to pour Seafoam into the motor as it is sucked into the intake manifold. Seafoam's instructions on the can actually intended it to be used this way.
12-08-2017, 09:49 AM | #4 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
It should still deliver sea foam to the top end of the engine, but you might not need it as much with DI engines. I bet there's still going to be some carbon build up from the crank case venting, but at the same time the build up might not be as severe since fuel is being added directly to the cylinders instead of to the air in front of the intake valves. Cleaning should still be accomplished, but maybe you wouldn't need to do it as frequently to get the same result?
2017 SS 1LE.
12-08-2017, 10:46 AM | #5 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
GM had similar "top engine cleaner" which was aerosol based. Techs use to do it one of two ways, through the TB itself, or by removing the brake booster line. I assume that you can still do that, with out a code of some sort being thrown. Seems these cars now days are freakin finicky over the dumbest things.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
12-08-2017, 11:20 AM | #6 |
Drives: 2000 GMPPSV SS & 2017 ILE SS Join Date: Jul 2017
I wouldn't run Sea Foam through my engine.... evidence of its effects are sketchy at best. Not worth the risk to sensors, etc. for me. Just change your oil regularly and use 93 octane.
12-08-2017, 12:02 PM | #7 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
But direct injection motors need there intake valves cleaned often as there is no gas ever hitting the back side if the intake valve which cleans the intake valve. |
12-08-2017, 12:38 PM | #8 |
Drives: 02 Camaro SS 6M / 11 GMC Sierra Join Date: Mar 2017
[QUOTE=Need4Camaro;10002651]I've been wondering this. Can I use Seafoam through the brake booster on my 17 Camaro 3.6L? I don't "think" I need to yet but if it ever came to past that
I did it to the llt in the last Gen Camaro with no issues and that was direct injection. and I guarantee you when it's time I'll use seafoam in my new Camaro as well. I don't know what I don't know what guys are talking about above me but seafoam really is the cat's ass and I use it in all my vehicles. And the brake booster line is the way to go |
12-08-2017, 04:07 PM | #9 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Just be sure to add it slowly. Don’t just stick the hose into the Seafoam container. It is technically possible to hydro lock your motor and really wreck some serious stuff. I’ve used Seafoam on other vehicles but not on my Camaro.
12-08-2017, 04:23 PM | #10 |
Drives: 2017 2SS black on black on black. Join Date: May 2017
I like seafoam products and use them.
As for carbon on the valves, I take the car out on beat run and blow all the carbon out of it. This is known as a German Tune up. Also as noted, I would be careful about hydro-locking the motor. Don't let it inhale the hole can in one gulp. The Brake boaster port can really inhale quite a bit. |
12-08-2017, 04:56 PM | #11 |
Drives: 2017 2lt rs Join Date: May 2017
Would think you could add a "t" fitting in line . I think the hose is 3/8 inside dia.and add a rubber vacuum cap on the open end. Try to find a "T" fitting with a smaller port to inject the sea foam.
12-08-2017, 05:10 PM | #12 | |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
12-08-2017, 06:04 PM | #13 |
Seafoam also makes an aerosol can with a long tiny tube bent in a U. It is intended to slip in alongside the rubber boot on your intake. I’ve used this too but if you really need to remove heavy deposits stick with the brake booster.
12-08-2017, 07:01 PM | #14 |
Is carbon build up on the valves a product of not using a catch can and inhaling all those thick hydrocarbons into the the engine?
