Old 01-28-2018, 04:59 AM   #1
95celgt
95celgt's Avatar
Drives: 2014 1LE 2SS coupe
strong throttle dead spot/bucking
Hey guys,
my 2014 1LE sat in the garage for December and when I brought it back up to central texas my xpipe slipped off of my longtubes on one side some how. Got it to the shop and pushed the exhaust back on an tightened the clamps back on. however while the exhaust leak was present and now still after I noticed a huge dead spot around 20-40% throttle with heavy hesitation like I can hold it and it hits a brick wall and power intermittently comes back on like a sputter but completely throttle or ignition related. Car has 35K miles and closest thing I can relate this to is as if my opti spark is intermittently working on my old lt1. once you go past the 40% throttle power comes back on hard with no hesitation whatsoever. car idles perfect.
car has a bo white ported throttle body and full stainless works exhaust.
pat g tune....car ran perfect for over a year until this happened.
could it be the TPS??
95celgt is offline   Reply With Quote
Old 01-28-2018, 06:32 AM   #2
appleman22
Drives: 2017 1ss 1le
Sound like a bad throttle body if I had to guess
appleman22 is offline   Reply With Quote
Old 02-04-2018, 11:30 AM   #3
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Throttle position sensor on the gas pedal......mine would buck and jerk under hard acceleration. bought a new one and no problem since......
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 02-04-2018, 11:44 AM   #4
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Did you get any CEL? Did you have the problem before or after you put on the VTC?
camguynj is offline   Reply With Quote
Old 02-04-2018, 04:38 PM   #5
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
I would Look into the throttle position sensor and the mass air flow sensor for issues. Just to be sure since you had exhaust issue I would look over the oxygen sensors too.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 02-04-2018, 06:13 PM   #6
bkscott
bkscott's Avatar
It was not the VTC it was a bad pedal sensor, even before I had the VTC it would do that....no cells were thrown till i added the vtc....
Old 02-11-2018, 09:07 PM   #7
95celgt
95celgt's Avatar
it was indeed the throttle body that went out at 35K miles -_- , thanks everyone!
