06-05-2018, 01:25 PM | #1 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
Tire bloom and tire coating
I hate tire Browning. Also known as tire "bloom", it happens to a lot of new tires and has to do with oxidation etc.… Here's an easy way to get rid of it for years. Use stoners tarminator to get the wheel clean, then rinse it with water, and apply a tire coating. Use an applicator, never spray tire. This is not a tire dressing, this is a true coating, so therefore it lasts 3-6 months....
Before: Finished The stuff: |
06-05-2018, 06:26 PM | #2 |
The browning or blooming is caused by an anti-ozonant that is added to the rubber during manufacturing.
This organic compound protects the rubber from premature deterioration caused by exposure to extreme weather elements. It prevents the material from drying, peeling, and cracking. The rubber compounds in your tire are engineered to retain a specific level of anti-ozonant to be continually pushed on the outside of the tire to protect the surface and the sidewall from oxidation. When the anti-ozonant is exposed to air, moisture, and heat, it quickly oxidizes into a brownish residue. That’s the story behind tire blooming. I've tried several cleaners, the Tarminator does work well. Adams tire & rubber cleaner also works really well. Dish soap will also work if they aren't really bad.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
06-05-2018, 06:31 PM | #3 |
Thanks Joe , I knew you would explain it. I really didn't care to. I just know that it's happened on every new tire I've ever had at some point. It really detracts from even the most perfectly detailed car.
I put on a shit armor all coating a few years ago, that looked like hell, and I couldn't get it off. I called armor all tech service and they recommend tarminator to get it off. Ever since then I've been a believer in the stuff for tires in addition to front end tar problems. I found that dish soap, reset or car shampooed will get rid of it, but it comes back, it doesn't come back for me with Tarminator. |
06-05-2018, 08:02 PM | #4 |
Camaros Of Northwest Ohio
Well you learn something every day. Thanks for the explanations. TAC System Tire Dressing helps some. More products to buy!
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
06-05-2018, 09:28 PM | #5 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
Tuf Shine tire cleaner is the strongest i have tried. Tarminator may be a bit expensive for me to use since I do so many cars.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
06-05-2018, 09:34 PM | #6 |
This is written for the guys that have tarminator on the shelf and use it on the front End. I've had the same Can of tarminator for the last three years, you don't do this more than once a year…And I'm sure whatever bug and tar remover anyone has , will work.
06-05-2018, 09:47 PM | #7 |
Drives: Fast Join Date: Mar 2015
Gotta try me some of this Tarminator...
Adam's Tire & Rubber Cleaner works really well for me. |
06-05-2018, 09:52 PM | #8 |
Tarminator is great stuff. I use 2 cans/month. Mostly for tar on wheels, of course.
06-05-2018, 11:12 PM | #9 |
Drives: Crush ZLE M6 | 2000 Corvette FRC Join Date: Jun 2010
Post pics of how that coating is holding up every couple months please! I can’t imagine a tire coating that would last through that many miles/washes etc. Interested.
06-05-2018, 11:36 PM | #10 |
Drives: Tesla M3 LR-AWD [Former 1SS owner] Join Date: Jan 2018
06-05-2018, 11:55 PM | #11 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Wesley's BLECHE WITE used to be the best but now since it was sold to black magic its not as strong but its pretty cheap...)
Tuff shine is still the best cleaner bar none. -bobby
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS |
06-06-2018, 01:45 AM | #12 | |
I posted it here on 5/9/16: https://www.camaro6.com/forums/showt...ighlight=Lasts |
06-06-2018, 07:55 AM | #13 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Thanks for the tip...I can't stand when they brownm usually for me after a heavy rain for days or driving in it, even with a tire coating. Will have to try this.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
06-06-2018, 02:11 PM | #14 | |
