01-17-2019, 09:01 PM | #1 |
Long hauler
Bumbleboy92's 1LT v6 Build
As is the usual story with parents buying their kid a car for college. I was fortunate enough to receive a 2016 Camaro 1LT v6 as my gift from my parents and brother.
I actually was given it earlier in November but didn't get around to this until now. Even now I can't post photos yet as I'm in the midst of doing the RS light conversion. In the description, a stock black v6. Will update with any photos from before and after the conversion. Edit: Transmission/Differential Info Sheet I made VIN: 1G1FB1RS7G0180689 (For whoever purchased it in the future, hope you treat it well) Last edited by Bumbleboy92; 07-23-2023 at 05:11 AM. Reason: Excel sheet |
01-17-2019, 09:06 PM | #2 |
Long hauler
Modifications
Completed
In Progress...
Planned
04-16-2019, 04:59 PM | #3 |
Long hauler
Accident
04-16-2019, 05:38 PM | #4 |
CamaroFan63
Drives: '15 1LT Summit White Join Date: Jun 2015
Oh Crap, Glad your Ok.
Auto/19's/Boston Acoustic speakers/Spare Tire
Born 10/28/14 Adopted 04/09/18 with 17,491.xx miles Oracle clear side markers / LLmar tint sides and rear. Strut bar / Husky Floor liners |
04-17-2019, 12:43 AM | #5 |
Long hauler
04-17-2019, 07:26 AM | #6 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
Pictures of the damage?
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
04-17-2019, 12:12 PM | #7 |
Long hauler
https://m.imgur.com/gallery/8V2JDn0
Damage isn’t as bad as it could have been, engine and most the body isn’t damaged. Trailer due to the rear wheel being hit and taking out the Stabilitrak |
04-17-2019, 05:51 PM | #8 |
Meh it sucks but it looks like only body panels are damaged and some suspension stuff.
Keep us updated when it will be fixed!
05-12-2019, 02:07 PM | #9 |
Long hauler
Light repairs/Wheel upgrade
All tabs on LH Headlight were broken, same with LH DRL. Bought one off eBay with all tabs intact but glass broken, so cut into both to switch the glass.
Also got a set of stock SS staggered wheels and staggered 245/40/20 and 275/35/20 Goodyear F1 runflat tires Pictures Also got a SS hood with the vents, another LT bumper with RS grilles, and new fenders. Believe the rear suspension work is fixed, needed to replace one of the links and bolts as they were bent, in need of alignment to make sure. Next up is frame work and paint |
06-13-2019, 03:40 PM | #10 |
Long hauler
Accident Related Repairs
From previous post: Frame work completed 05/21/2019
Alignment done 05/24/2019 Needs front right side tie rods and rear left welded bolt has to be rewelded. Fenders and bumper put on, now paint Normal post: Got rear wheel nut holder welded and installed new tie rods on the passenger front. Installed rocker panels from back when the alignment took place. Needs new alignment and that should be it! Edit: Alignment was done, slightly off-center but I think it's either the shop or very slight adjustments needed. - 07/03/2019 Edit: Installed new tie rods on the driver front. - 09/27/2019 Edit: Installed new sway bar end link on driver front - 10/12/2019 Last edited by Bumbleboy92; 06-08-2020 at 03:02 AM. Reason: Sorting |
11-04-2019, 04:23 PM | #11 |
Long hauler
Service Records
04-26-2023, 09:49 AM | #12 |
Long hauler
This chapter closes…
Retiring the signature: Car Journal Overkill Tune 93/AFM Off - K&N CAI - Ported 80mm Throttle Body - Ported Intake Manifold 4 Piston Brembos - FE3 Shocks - Eibach Pro Springs - BMR Lower Control Arms - MeganRacing Toe Arms ZL1 Factory Axle-Back (AFM Valves deleted) - Jones SXP6SS X-Pipe (Stock resonator deleted) Happiness: Infinite.
04-26-2023, 11:47 AM | #13 |
Sorry to see it. Hopefully you'll be back with another one!
2020 Camaro 2SS - Riverside Blue, NPP, Magnetic Ride, Sunroof
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
04-26-2023, 12:30 PM | #14 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
Aww man, so sorry to see your car damaged . What happened and what's your a plan going forward?
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
Tags |
2016, black, non-rs |
