#Camaro6
Old 09-20-2019, 11:10 AM   #1
Freedurt
Freedurt's Avatar
Drives: 2018 SS 1LE
Gotta couple newbie questions about taking the wheels off (2018 SS 1LE)
I feel stupid but oh well. I got a flat in my sidewall tire this morning in my front tire :( gotta replace em both now
I’m gonna just take them off myself and drop em off at discount tire, and then install the wheels back on myself.
When y’all torque do you torque wheels in the air or wheels slightly touching the ground?
Are the OEM Eagle F1 Supercar 3 tires considered directional or symmetrical?
Any tips to not **** anything up?
Freedurt is offline   Reply With Quote
Old 09-20-2019, 11:26 AM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
loosen lugnuts, jack up car take off lug nuts, remove wheels
easy as pie! make sure to order some jack pads or lift helpers from zl1 addons they help alot!
torque on wheels is 140lbs and i believe they are directional so you can rotate but just side to side
kropscamaro16 is offline   Reply With Quote
Old 09-20-2019, 12:32 PM   #3
wwiiavfan
Drives: 2017 1SS Hyper Blue
Install lug nuts snug while still on the jack.
Torque on the ground in a criss-cross pattern.
Always a criss-cross pattern.
wwiiavfan is offline   Reply With Quote
Old 09-20-2019, 12:32 PM   #4
rayhawk
rayhawk's Avatar
Drives: Camaro SS
Just be careful with where you lift the car from, especially the front. Make sure to only use the jacking locations. I like to hand tighten the lugs by just holding the wheel, then lower the car and torque them down. Pretty sure the tires are directional so make sure you get a left and a right.
rayhawk is offline   Reply With Quote
Old 09-20-2019, 12:41 PM   #5
JT58
Drives: Former 2016 Camaro 1LT
You always want to torque with tires and wheels on the ground. I hand tighten with the lug wrench (or very lightly with the impact- note very lightly) when the car is jacked up. Then I jack it almost all the way down- just enough pressure to keep the tire from turning and hand torque each lug nut is a criss cross pattern as already noted. Then jack it all the way down. Very easy to do by yourself. Just make sure the jack is placed in the correct spot and is not under the body fenders or rockers. Some dealers seem to even damage some cars by jacking them up incorrectly. I shudder when I see and read about those instances on this forum.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
Old 09-20-2019, 01:24 PM   #6
TJay74
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC
For the most part correct, except the tires are not directional. They are asymmetrical and you can swap the tires on the wheels side to side with no issues as long as the side of the tire marked "Outside" is on the outside of the vehicle.
2019 Corvette Z06 2LZ A8 - Halltech CAI, AWE non-catted X-pipe, Mamo V2 ported TB 592rwhp, bone stock 566rwhp
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
TJay74 is offline   Reply With Quote
Old 09-20-2019, 02:57 PM   #7
RKeeton
Drives: 2013 BMW M3
Don't forget the TPMS are specific to a wheel position.
RKeeton is offline   Reply With Quote
Old 09-20-2019, 03:12 PM   #8
blackgloves
blackgloves's Avatar
Drives: 1987 Iroc Z/28
I live in College Station TX. Bring it by the house, I'll show ya.
Current:
1987 IROC Z28
2021 GMC Canyon Elevation
Former:
2019 2SS (Crush)
1978 Z28
2006 SS/SC Cobalt
2001 Z28
1999 Chevy S-10 Extreme
1972 Z28
1984 Z28
blackgloves is offline   Reply With Quote
Old 09-20-2019, 03:14 PM   #9
Freedurt
Freedurt's Avatar
Drives: 2018 SS 1LE
Whatcha mean?
Old 09-20-2019, 03:23 PM   #10
RKeeton
Drives: 2013 BMW M3
Originally Posted by Freedurt View Post
Whatcha mean?
Inside each wheel is a tire pressure monitor. Each is programmed to a specific position on your car. If you reverse them when you put the wheels back on, you will have to reprogram them so they will be reporting correctly on your display. Or take them off and move them to the other side of the car. Not a big deal but if you mark your wheels left and right you will be good.
Old 09-20-2019, 03:27 PM   #11
Freedurt
Freedurt's Avatar
Drives: 2018 SS 1LE
Oh ok, gotcha
Old 09-20-2019, 07:18 PM   #12
Freedurt
Freedurt's Avatar
Drives: 2018 SS 1LE
Thx everyone, all great advice
2018 SS 1LE Blacked Out
Tail lights: GM Dark finish tail lamps
Side Markers: Diode Dynamics LED Sidemarkers tinted
3rd Brake Light: GM ZL1/1LE Dark 3rd brake light
Rear Reflectors: Hero smoked rear reflectors
Debadged sides, rear, black front SS Badge, black bowties, paint corrected, ceramic coated with CQuartz UK 3.0
