Old 11-21-2019, 07:51 AM   #1
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
Do I really need better axles?
Got 2012 SS auto with Twin Turbos. only 10 PSI and about 650wrhp.
I dont race at track and would never put drag's on it. No issue letting the tires spin
I dont have any issues now. other than one axle boot has been cracked for years and grease been coming out.
I am upgrading Diff to AAM 3.91 gears and Detroit Truetrac POSI.
I was going to just get new OEM axles, to replace bad boot one and might as well do both for the price of $370 shipped.
So my question is do i really need 1,000HP axles? or will the OEM be ok with the new 3.91's?
i was thinking i could always go better axles in future if needed. But when doing Diff i wanted to do it right the first time.
KalCorp is offline   Reply With Quote
Old 11-21-2019, 08:25 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Been using 1LE axles(larger outer CV) off of ebay for $200 used for over 3 yrs with lots of trips to the track usin dr's and mostly 1.7 60' and lots of hwy miles too...no probs.
I also upgraded to 3.91's and have a 6M which hits the rear harder than auto.
make sure to replace the axle seals at this time too! cheap insur
so to answer you Q and based on your driving spec's above you should be fine...tho you must be replacing the rear's frequently right?
l8tr
PEACE
Old 11-21-2019, 09:05 AM   #3
KalCorp
Space Coast Camaros
KalCorp's Avatar
Do you think the 1LE axles will fit a 12 SS A6 diff? if so i will look into that.
this should be it? ---> 1LE Axles PN 22806796 and 22806795
Seals and bearings all getting replaced when doing diff.
I only Replaced the tires once. (315/35R20 Continental Extreme DWS) back in 2013 lol still got them. but its getting time to replace again. So i think i will be fine.
And thanks for feedback!
Old 11-21-2019, 09:11 AM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Probably better to replace suspension parts to prevent wheel hop. Contact BMR for recommendations.
Vegas Bound is offline   Reply With Quote
Old 11-21-2019, 10:22 AM   #5
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks! Did all that years ago and trailing arms.
But i think i might replace the BMR Diff bushings (Black) looks like they are going bad. will know more when it take Diff out. Might get the BMR red ones this time.
also got this from someone. its the 1LE axles
1LE LH Axle - 22806795
1LE RH Axle - 22806796
1LE Axle Nut - 11611234 (x2)
Washer for the hub end, 11611965 (x2)
Anyone done this before? is this correct?
Should be ok for me and under $400 and not $1200 for 1khp axles.
Old 11-22-2019, 01:28 PM   #6
LaN-
Drives: 2014 SS Convertible
If your car is lower look at offset diff bushings to help the axle angles.
Engine: LSA Conversion, Ported Heads, 1 7/8 headers, VMS 2.5 Cam, Roto Fab intake, ADM Scoop. BMR engine mounts, 3.91
628/525
Suspension: Koni orange, (BMR everything) 1" drop springs, toe rods, trailer arms, non adjustable LCR, FE4 sway bars, sub frame connectors, delrin sub frame bushing and upper control arm bushings. Front bushings.
LaN- is offline   Reply With Quote
Old 11-22-2019, 01:43 PM   #7
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks
Yes its as low as you can get static now. But I am looking into a Airlift package So driving might be normal height or little lower.
Also might get a used set of DSS 1000hp axles. i have to check if its needed for them.
Old 11-22-2019, 11:55 PM   #8
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
I run 1le axles. I’m similar if not a little more horsepower and I drag race with 17’s and drag radials. Haven’t broken them yet! Lol. They’ll fit any SS. As far as I know all SS’s have the same diff, manual or auto, so all the axles (auto, manual, 1/le) are interchangeable. Good upgrade without spending an arm and a leg
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 11-24-2019, 07:10 PM   #9
oldman14ss
Drives: 2014 1ss camaro
better axles
thanks frankwjr, I also was looking for an alternative to stock SS axles this is the second time you've helped me and ive listened to you and your voice of experience. thanks frank. the oldman........
oldman14ss is offline   Reply With Quote
Old 11-25-2019, 07:31 AM   #10
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I'll chime in as well - if you're not going on the drag strip with sticky tires, and you know how to close the throttle if it starts to wheelhop on the street - then you don't have much to worry about. I like to think of the stock axle as a fuse, protecting more expensive parts (like the diff). I definitely wouldn't worry about it - stay with stock and/or stock replacement and have fun!
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 11-25-2019, 07:37 AM   #11
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks everyone!
Hard to get OEM axles right now damn strike issues. and DSS ones are 6 month Back order i hear. lol
Going to update the Diff and do Air Ride. so trying to get all the parts so I only have to remove stuff once.
Old 11-25-2019, 08:13 AM   #12
KalCorp
Space Coast Camaros
KalCorp's Avatar
Looks like the Left (22806795) is on back order from GM. Everything else they can get.
Damn. :-(
Old 11-25-2019, 08:23 AM   #13
frankwjr
frankwjr's Avatar
ur welcome bro!
Old 11-26-2019, 08:18 PM   #14
oldman14ss
ordered mine this morning also, now snowball effect takes over, toes,and boxed arms in the works. might go with true track and 33;91s
