04-17-2020, 02:06 PM | #1 |
Drives: 2013 Camaro SS Join Date: Jan 2020
DIY Side Mount Sub Box-Done!!
So I am a DIY'er and hate to buy things I can build for the most part. It is fun thinking up projects and using your own hands to save your family dollars, especially in today's world. I wanted to add an 8" sub and amp as I don't listen to rap and just wanted to round out the BA system in my 2013 SS. I didn't want to see the amp and like the Sub-Th solution of Altrend SBA (sealed box amp) concealed in the end of the box. I also had some 3/4" plywood lying around (I know MDF is better).
So I got to work with cardboard, then the bottom plate, then the box part, then the fascia board, fitting the speaker, amp and carpet. Sourced the speaker and amp from amazon, the wiring kit and carpet from parts express and that was about all I needed. I spliced the wiring in and soldered them. Easy peazy, took like 30 minutes max. Tapped the battery positive and grounded the amp near the rear seat column. I omitted the bass control knob as it didn't seem to do a lot. Overall I am happy with the system. Hits pretty good and rounds out rock and country very well. It does shake the mirror, but I only have the gain turned up 1/2 way until it breaks in and I can push it to distortion to see the upper limit. I have order a Kicker 10" grill to fit overtop of it and will install this weekend. Anyway, hope this helps to motivate someone to try it. It really was easy. I used a sabre (jig) saw to cut the box and drywall screws. Take your time and cut slowly and you can make a nice finished product. Good luck!
2013 2SS Blue Ray Metallic/Silver stripes, black Interior. Halo conversion, Diode Dynamics grill lighting, LED interior and fog lights. Sundown 8" DVC, Altrend 300.1 Amp, Handmade side-mount box. Soon to be BBK Headers and hi-flow cats.
04-18-2020, 03:32 PM | #2 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2016
Looks good. Why plywood and not MDF though? Just curious
04-18-2020, 04:13 PM | #3 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
That was going to be my question. I agree though it does look good
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
04-19-2020, 03:52 AM | #4 |
Banned
Drives: 2015 Camaro Join Date: Aug 2018
Wow, that looks very professional. Great job!
04-19-2020, 06:09 AM | #5 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Awesome
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
04-19-2020, 06:54 AM | #6 |
Had some lying around Sent from my iPhone using Tapatalk
04-19-2020, 06:56 AM | #7 |
Thanks mikeman! Sent from my iPhone using Tapatalk
04-19-2020, 06:59 AM | #8 | |
Thanks!! Sent from my iPhone using Tapatalk
04-21-2020, 09:36 AM | #9 |
I just installed a mdf box man is it heavy. the jl woofer didnt help either.
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
04-21-2020, 02:07 PM | #10 |
Drives: 2011 2SS/RS Join Date: Feb 2016
Go Birch next time. Light and much more structurely sound.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
04-21-2020, 06:41 PM | #11 |
Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
Nice work
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
04-22-2020, 06:56 AM | #12 |
04-22-2020, 06:59 AM | #13 |
So I finally got it tuned up and the crossover set and man it can pound for a little 8”! Played a bass track on you tube and it shakes the mirrors and has no audible distortion. Very happy with it for my kind of music. If you play rap or would replace the factory speakers I think I would go 10”. Sundown 8” and Altrend 300.1SBA amp. Amp barely gets warm.
04-29-2020, 08:18 PM | #14 |
Got my speaker grill finally done. Extended a kicker grill 3/4”, added the center cap, sanded primed and painted it all. Sent from my iPhone using Tapatalk
