Old 05-18-2020, 01:44 PM   #1
Steves ss
Steves ss's Avatar
Drives: 2010 Camaro SS/RS Black
3:91 Gears.
Thoughts on upgrading to this gear set. Did any one do this, and if so is it a good performance upgrade? What’s drivability like? I have the 2010 Camaro SS with the L99. Thanks.
Steves ss is offline   Reply With Quote
Old 05-18-2020, 02:57 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
tons of threads on this...for me one of the best upgrades I did and I'm manual...don't forget gonna need a tune to correct the speedo..get a SCT/tune deal from dynoSteve at RDP...kill 2 birds with 1 stone.
Good luck!
PEACE
Old 05-18-2020, 10:41 PM   #3
chrish70
Drives: 2015 ls3 camaro ss
Good luck!
PEACE
chrish70 is offline   Reply With Quote
Old 05-20-2020, 10:27 AM   #4
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
I did this 3 years ago. Great upgrade and driveabilty if great. Right at 2100 rpm at 70 mph.
Modernmusclecar is offline   Reply With Quote
Old 06-17-2020, 06:51 PM   #5
06blownSS
06blownSS's Avatar
I took the drivetrain off a ZL-1 so I am running 3.73 in the rear and I love it. I would say depends how much power you plan on running, if you stay roughly stock 3.91s would be fun as hell. Higher hp levels peace of mind in a ZL1 diff and a more useable 1st gear was my choice. Do the gears you will not regret.
Black on Black on Black 2010 Camaro 2SS LS3;K&N intake, Dynatech 1 7/8 catted LTs, Borla S Cat Back, Eibach prokit, Pfadt rear trailing arms, ZL-1 driveline, BTR Stage III Cam, Tuned by Performance Redline 444.1whp & 442.9 ft-lb
06blownSS is offline   Reply With Quote
Old 06-19-2020, 10:55 AM   #6
DINGO
DINGO's Avatar
Drives: 2010 CGM 2SS/RS M6
Hi Steve
I put in the 1LE 3.91 and I love them. My car has a mild cam, the gears made a big difference.
If your planning on forced induction, then I would stay stock gears.
I am in Brampton also, hope to see you out on the roads.
DINGO is offline   Reply With Quote
Old 06-19-2020, 12:17 PM   #7
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Gears are definitely one of the best things you can do for these cars. They are heavy, and really come alive when give them some mechanical advantage.
We do carry the 3.91 (and 4.11) ratios on our website. If you have any questions, feel free to reach out.
https://gwatneyperformance.com/produ...gn=391scamaro5
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-19-2020, 07:22 PM   #8
Steves ss
Steves ss's Avatar
Thanks. I plan on staying N/A. Hey Dingo where did you get your gears done?
Old 06-19-2020, 08:59 PM   #9
Modernmusclecar
SpI near Hamilton did mine. They deal with a shop that specializes in drive lines. They install the gears in a diff at their shop and keep them in stock. Spi just called and had one delivered while shipping mine back to them. Drove right from there to the drag strip. That was 3 years ago.
Old 06-19-2020, 09:00 PM   #10
Steves ss
Steves ss's Avatar
So, this is what I have now, long tubes, x pipe, cat back system, cold air intake, 160 degrees thermostat, and a tune. Had this work done about 4 years back. When I drive in tap shift mode the car really moves and 1st gear is really short. How will the 3:91 gears make a difference when driving the car, or when I modify the car further do I need them for supporting my upgraded mods?
Old 06-20-2020, 09:50 AM   #11
DINGO
DINGO's Avatar
SPI
354 MacNab Street
Dundas, ON
L9H 2L2
sales@2020speedshop.com
tel:1-289-238-9471
also consider doing new bushings, while the unit is out of the car.
I've been bring my Camaro to them for 10 years now.
Old 06-20-2020, 11:49 AM   #12
Steves ss
Steves ss's Avatar
Thanks Dingo. I started to email a few shops and that was one of them. I was told they were going to send me an estimate.
Old 12-28-2021, 11:56 PM   #13
sean_reaves33
sean_reaves33's Avatar
Drives: 2011 camero ss
I have a 2011 camaro ss modded : i have 3:91 gears on a upgraded transmission that handles 1000 hp. Got the 2.9 whipple wit the nick Williams 102 boosted TB, makes a difference. headers, cat delete and auxiliary pump which handles 1000hp.
Now CHVYMAC mustang dyno 840 rwhp. It's pretty fast but when i get past 160mph it blows out a lil water while running 170+ and it still be pulling. Tring to figure if the gears are to low to be doing pulls at 150mph? Now if i just press the gas and get to 170mph no problem, but if i do a pull from 150mph then a lil smoke come from underneath the car. Once i slow down smoke stops. Then everything seals back up. No leaks nothing. Therefore i can do pulls up to 160mph no problem. Or do you think its a tunning error? Or engine compression issue. Maybe a bigger cam? Appreciated your feed back..
Sent from my SM-G965U using Tapatalk
sean_reaves33 is offline   Reply With Quote
Old 12-29-2021, 01:20 PM   #14
Steves ss
Steves ss's Avatar
Hey Sean. Nice car. Like your set up. I’m not sure about your situation. Sorry bud. What wheels and tire setup do you have?
