Old 05-19-2020, 04:59 AM   #1
'10CamaroDude
Drives: 2010 Camaro LS
Calibration needed?
After replacing VVTs, is there any kind of calibration procedure, other than
just pulling power from the ECU? Just wondering, replaced spark plugs,
a few VVTs, and it got a little worse... I did not pull ECU power yet,
I will today, but I am just wondering if there is a calibration for VVTs.
I put new VVTs in, and I get hesitation under acceleration. It was fine,
kind of, but I put a newer on in place of another newer one, and it
started that again.
'10CamaroDude is offline   Reply With Quote
Old 05-19-2020, 08:36 AM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Not sure I understand the question and I'm not sure anyone else would by extension. When you say VVTs do you mean valvetrain components and sensors?
DSX_Camaro is offline   Reply With Quote
Old 05-19-2020, 05:00 PM   #3
'10CamaroDude
VVT - Variable Valve Timing Solenoid. Most people just call them VVTs. Some call
then OCVs. It's a simple question, do they need calibrated, or not...
Also., I don't know what you're "I'm not sure anyone else would by extension." refers
to, I said absolutely nothing about any extensions, anywhere, in any language.
Old 05-19-2020, 05:53 PM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
Are you an ESL student?
Vegas Bound is offline   Reply With Quote
Old 05-19-2020, 09:28 PM   #5
navigation13
navigation13's Avatar
Drives: 2015 2LT/RS
started that again.
No there are no calibrations but I think pulling power from the car is recommend so that the car can start over on its fuel trims and stuff. It might be hesitating because the car thinks its still got the old stuff it had adjusted too.
navigation13 is offline   Reply With Quote
Old 05-19-2020, 10:01 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
"buy extension" would be purchasing. "by extension" means in addition to. VVT means Variable Valve Timing yes which is a mechanical system, so when you say you replaced your VVTs that gives no clear information. I literally had no idea what you were asking which is why I said "anyone else by extension" as in if I didn't get it, I'm pretty sure no one else did either. Not trying to be an ass or anything, but in context it was not a simple question. You replaced your "VVTs". Did you replace cam sensors? Cam phasers? Camshafts? Entire valvetrain? Do you see what I was trying to ask originally? That's all.
Also yes just pull the battery cable like you said in your OP and get back to us, if you haven't already. Have you checked your ignition coils too? Hesitation is a broad issue so...
Old 05-21-2020, 07:11 PM   #7
'10CamaroDude
I pulled #5 and #20 fuses, waited 5 minutes before putting them back in.
Just wanted to know if the KAM needed to be erased, well, I got the answer
anyway, yes... Car ruins totally different, much better.
After starting it, I let it idle to hot, then A/C on for a minute, then off.
Then idle in gear, then idle in gear A/C on. So, went through the whole
basic idle learning process.
The hesitation goes away with 89 octane fuel, but not with 91 or 93. It's
smoother acceleration with 89 octane.
