05-23-2020, 10:42 PM | #1 |
Drives: 2012 45th Anniversary 2SS Join Date: Dec 2011
ISO Door window wiring diagram
Does anyone have a wiring diagram for the door? My passenger window isn't going up and the car doesn't even seem to recognize it to try and calibrate it. Trying to see if there is an issue in the wiring somewhere. Thanks.
05-24-2020, 12:05 AM | #2 |
Drives: 2022 Chevy Camaro 2SS Redline Join Date: Dec 2016
In the past. I have gone to a chevy dealer's parts department and they have provided me with a complete assembly diagram of said part in question. Sometimes if you choose your keyword searches on google. You can find the diagram and the complete assembly of related parts in PDF.
05-24-2020, 01:28 PM | #3 |
It's going to take me some time to get it all together but I will start posting some info in here for you. I have been dealing with driver side window issues for over a year. Unfortunately, with your issue being on the passenger side it actually makes things a little more difficult to troubleshoot, as the problem can be rooted in either the driver side (master switch/wiring or passenger side switch/wiring).
I will post or PM full window wiring schematic (Window Schematic.pdf), switch and connector pinouts, and door blowouts. Some of the diagrams are corrupt, but you should still have enough info to start troubleshooting. It is easy to determine if the issue is a switch or window motor as you can apply ground to the pins for 'Master Passenger Up' command at both the passenger and driver's door window switch connector (Pinout Diagram attached). If the window goes Up while bypassing the switch...it is likely the switch. Just keep in mind that the Driver's side switch MAY override the Passenger side, so I am not sure if a bad driver's side switch will cause loss of related controls on the Passenger side, even if the Pass side switch is good. Also included is the GM diagnostic troubleshooting/testing flow for each window. I would suggest ordering a bag of these or similar from another manufacturer (This brand is brittle). Every time I take my door panel off to work on the window I break at least 1 or 2: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Finally, there may be some duplicate information between the pdfs. Good luck and please let us know what you find.
05-24-2020, 10:12 PM | #4 |
Thank you so much! This will be super helpful!
