05-29-2020, 10:56 AM | #1 |
Drives: Imperial blue 2010 2ss Join Date: Feb 2017
Clutch pedal issue
under heavy acceleration at higher speeds the clutch pedal sucks towards the floor. Still can disengage and engage the clutch but the travel isn't all there. I have to physically pull it back up with my foot. I'm at 808 whp on 8psi of boost. Have a McCleod RXT twin disc installed with brand new slave, separate clutch resevoir, using Motul RBF 600 dot 4 fluid. I was told possibly the spring or the master but not sure I want to remove the spring and leave it out. Can anyone help me out?
05-29-2020, 11:56 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Did you install a billet bearing support on the slave cylinder?
05-29-2020, 12:53 PM | #3 |
Drives: 2015 2ss Join Date: Jun 2009
you've done most of the fixes already, however as Larry said a billet bearing support on the slave will go a long way, but IMO the last thing you're missing is the Tick Master Cylinder for our car. that's what finally stopped my pedal issues. also i'd say bleed your clutch and get some fresh DOT4 fluid in there.
https://www.tickperformance.com/tick...4-17-chevy-ss/
2015 Camaro 2ss, NicKey Performance built/tuned |
05-29-2020, 02:45 PM | #4 | |
05-29-2020, 07:44 PM | #5 |
Drives: 2013 1ss Join Date: Jul 2012
What is the reason for using dot 4. My car calls for dot 3.
Also, I had a tick master cylinder from the pre order run and it didn't make it 5k miles. I kept losing adjustment and when I replaced the clutch system it did not build enough pressure to release the clutch. Switched back to new gm original equipment master cylinder and problem was gone. |
05-31-2020, 06:24 PM | #6 | |
i've had mine for over a year installed with zero issues, you won't regret it
05-31-2020, 08:57 PM | #7 | |
I'm glad yours works well for you. As with most products, some people are happy and some are not. I would think that a company testing out the design on their 1st generation of product would contact the 1st generation customers to see if they needed assistance with the identified flaw |
08-11-2020, 12:47 PM | #8 |
Unapologetically American
What are the observed symptoms if the stock bearing support fails?
Curious, because I get a noise when releasing the clutch pedal...like a fluttery bouncing piece of metal. Also I get a knocking sound as the RPMs increase. I'm wondering if this is due to that support going bad. 2010 Camaro SS LS3 w/ 25,000 miles on it.
2018 ZL1
08-11-2020, 02:48 PM | #9 | |
I didn't want to take any chances while I had everything apart so I installed a new slave cylinder with the billet support, new bearing, and a remote bleeder.
