06-12-2020, 02:52 AM | #1 |
Drives: 2017 Camaro 1SS Join Date: Jul 2019
Wheels doesn’t fit
https://imgur.com/ZxYG1ae
Recently bought a set of Curva C300, they looks great and the price is attractive. Front:20x9.5 30mm offset Rear:20x10.5 30mm offset Also bought a set of Nitto NT555 Front:265/35r20 Rear:285/35r20 Front was about 2mm close to the lower part of my suspension when my car was lifted up, rear was about 5mm close the inlet fender. |
06-12-2020, 04:15 AM | #2 |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
5mm spacers
06-12-2020, 07:10 AM | #3 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
It sounds like they are barely interfering. I have 20 X 10 square with 27535R20 tires, wheels machined to a 28 MM offset and they clear. Tires poke out just a tad though.
Easiest solution is 5 MM spacers. You might even get by with 3 MM Spacers.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
06-12-2020, 08:31 AM | #4 | |
Drives: 2016 2SS Convertible Join Date: May 2012
06-12-2020, 01:37 PM | #5 |
Thanks for all the comments, I just figured out the Mavis Tire Shop ( 2507 Park Road , Charlotte) put my rear tires on the front rims and front tires on my rear rims. Yes, it’s unbelievable, they did not program my new tire sensors and didn’t balance my tires either. I went to another shop and they fixed the all the mistakes. My front tires are like 1mm close to the lower struts. I hope that’s fine.
06-12-2020, 01:46 PM | #6 |
Now I’m having another issue, my car vibrates/wobble after 50mph. Seems like tire balanced incorrectly. Hopefully it’s not bent rims. I’m just having a really bad day.
06-12-2020, 01:56 PM | #7 |
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Take it back to the shop that re-did the other shop's mistakes and tell them to check the balance.
Tags |
fitment, rims, rubbing, tires, wheels |
