Old 06-14-2020, 09:25 AM   #1
Tpeeler31
Tpeeler31's Avatar
Drives: 2011 Chevrolet Camaro 2SS/RS
Stock Ported vs Aftermarket Heads
Hey y’all,
My name is Ty and I’m new to the forum. Ive been looking, and looking, and looking on the forum at old threads discussing this (I apologize in advance if I’m opening up a can of worms) but basically I’d like to know what route y’all took for modifying your heads and why. The new heads will be going on a 2011 L99 with a TSP VVT 2.2 camshaft (227/239 113lsa .629” lift), JLT intake, and 1 7/8” headers. The goal is the biggest bang for the buck. I’d like 500rwhp but won’t be heartbroken if I don’t reach that number as boost down the road could easily fix that. Also, being my car is fat, torque under the curve is just as, if not more, important to me than peak HP. I’m on a budget and would really not like to go over $2500.
Any constructive input is greatly valued!
Tpeeler31 is offline   Reply With Quote
Old 06-14-2020, 11:35 AM   #2
07-SRT
07-SRT's Avatar
Drives: 2015 Camaro SS
Keeping the VVT , that cam with L99 and auto you will be more around 450 rwhp ( depending on Dyno and correction factor used) If you only goal is nothing more than "500 rwhp" just save up for forced induction.
2015 Camaro 2SS
Cam/Heads/FBO 498/447 SAE
07-SRT is offline   Reply With Quote
Old 06-14-2020, 12:01 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
The cheapest route for heads is to send you factory ones and have them ported. They wont flow as much as aftermarket but should be better. 500 rwhp on a L99 is hard to do id say set your goal to 480
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 06-14-2020, 02:50 PM   #4
Tpeeler31
Tpeeler31's Avatar
Thanks for the input guys! I’ll probably look at TSP OR GPI’s porting services for the stock heads. However, I came across the GMPP heads and am considering them also since they are in my budget and I could sell my current heads. Plus I’d get hollow-stem intake valves which is a plus. I guess I’ll continue to do some more research!
Old 06-14-2020, 02:57 PM   #5
07-SRT
07-SRT's Avatar
If I recall the springs on those GMPP heads are only good for up to .550 lift, you will need to upgrade the springs
2015 Camaro 2SS
Old 06-14-2020, 03:20 PM   #6
Tpeeler31
Tpeeler31's Avatar
I will swap springs since I’m currently running the BTR dual spring
Old 06-14-2020, 04:33 PM   #7
Roader
Drives: Camaro
If you want to chase 500rwhp then mill them to bump compression and add flex fuel sensor and use e85
Roader is offline   Reply With Quote
Old 06-14-2020, 06:14 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Mill and light port, if any. Stock heads flow plenty to support a lot of power. The real advantage of aftermarket is extra PTV room, and the flow too. So big cam extra compression is good.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 06-14-2020, 06:45 PM   #9
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I wouldn't waste your money on heads if FI is in the future plans, put that money towards saving for the FI. Stock heads flow well.
Greenhornet2 is offline   Reply With Quote
Old 06-14-2020, 11:34 PM   #10
Tpeeler31
Tpeeler31's Avatar
That’s a good point actually. After doing the research it would be a big chunk of change for the heads, gaskets, bolts, etc. That being said, how do you like your Whipple?
Old 06-15-2020, 02:17 AM   #11
Bo White
Bo White's Avatar
Ive ran stock ported and aftermarket heads. I gained both times.
Old 06-15-2020, 02:18 AM   #12
Bo White
Bo White's Avatar
Ported or aftermarket heads on a power adder car is just as beneficial as on a NA car.
Old 06-15-2020, 05:29 AM   #13
eLeSthree
Drives: 2011 Camaro SS 6sp
Yes, and if the OP has a budget of $2500 for heads, I would be taking a hard look at the Frankenstein M311 heads from Thompson Motorsports. They come with a nice spring set, and if I recall correctly you can have them milled down to regain your compression, since they are 72cc. They usually go for $2400 at TMS, and you just missed a sale where they were $2000. These are 6 bolt heads, which you wont need to use on your stock block, but thats fine. No problem running 6 bolt heads on the stock block.
https://www.thompsonmotorsports.net/...cylinder-heads
The second option I would consider, is the TSP 6 bolt "as cast" head. If you already have a good valvespring kit, they would cost you about $1750 for a nice set of 6 bolt heads.
https://www.texas-speed.com/p-7650-p...der-heads.aspx
I know you dont need 6 bolt heads now, but if you're planning forced induction, you may end up with a 6 bolt block someday, and you'll have a bad ass set of heads to clamp down and hold all the sauce.
Again, thats if you have a head budget for $2500.... If not, spend it on boost. You'll get 20-30hp with just heads, or 200-300hp with boost.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 06-15-2020, 08:20 AM   #14
Tpeeler31
Tpeeler31's Avatar
Thanks for the help y’all, the more info the better. I was not even aware of the Frankenstein heads and will look into those. Now I’m torn between just boosting and being done with it or doing heads now and boost later to leave no stone unturned so-to-speak. I think I’m at the point to where conservative boost would be the better route. I heard the stock heads flow pretty well up until 600-700 range before they become a choking point. Does that sound about right?
aftermarket heads, heads, ported heads
