07-15-2020, 12:29 PM | #1 |
Drives: 2021 Camaro LT1 Convertible Join Date: Apr 2019
Caliper paint
I'm looking to paint my calipers. What kind of paint do you guys recommend? Any special tips when doing this? I've only had them painted by a shop near me. I have the 2020 LT1, so brembos in the front and normal calipers in the back
07-15-2020, 12:55 PM | #2 |
Drives: SS A8, NPP, Red Hot Join Date: Jan 2019
VHT makes caliper paint. No experience with it, but it's gotta be flameproof.
07-15-2020, 01:01 PM | #3 |
Retired from Car mfrs....
Drives: 2LT RS/HR-V Join Date: May 2013
https://www.g2usa.com/
But buy a new horsehair brush at Lowe’s, the brush in this kit is shit. But the paint is the best. |
07-15-2020, 01:21 PM | #4 |
I have used this kit-
https://www.autozone.com/paint-and-b...kit/539677_0_0 I really wanted black but only red was locally available. My main purpose for painting the calipers was anti-corrosion, not cosmetic. The Duplicolor kit works well and has held up nicely, but as Glen e said, buy another brush because the one included in the kit is basically useless. It will take 2-3 thin coats to cover without streaks. Don't even try to do it in one thick coat, all it will do is sag or run. If you set up all four corners for painting by the time you finish the last caliper you can start over and go right into the next coat. It is semi-transparent so if you want a super bright and uniform color you must use an undercoating to evenly hide the original caliper surfaces. Unless of course they were already painted as Brembos usually are. If you want more color selections, G2 would by far be your better choice.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
07-15-2020, 01:41 PM | #5 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
I used the Dupli-Color brush on (red) and spray (Silver). The red was on my 2011 Mazdaspeed 3. I painted them while they were mounted and masked certain areas. They came out OK. The paint chipped in a few areas and it was easy to touch up. The spray was on my 85 Corvette, which I took the calipers off and was able to spray them. The spray came out better than the brush and held up better, no chips. (It also could be that the wheels were not nearly as open as on the MazdaSpeed 3).
I would go with spray paint if I had to do it over again.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
07-15-2020, 03:14 PM | #6 |
Drives: 2016 SS Join Date: Oct 2019
I've used Duplicolor spray and brush, as well as the G2. The Dupli spray worked, but I felt the red finish was more dull than the brush on. The Dupli brush on works great, and holds up really well. The G2 also holds up, but I felt the G2 just applied a little less even, and had some brush strokes. Seemed to dry quicker. But they have TONS of colors. Which is nice.
Get a few good brushes....they one's the come with are crap, lol |
07-15-2020, 03:29 PM | #7 | |
Go Arizona Cardinals
Drives: 2006 GMC Duramax 2500 HD, 2016 2SS Join Date: Sep 2015
2015 Nissan Murano SL with Tech Package
2006 Lifted GMC Duramax 2500 HD. Lot's of custom parts! 2016 2SS Garnet Red 2SS,6 Speed, NPP, MRC, Adrenaline Red interior, Black Rally Stripes, NAV, Sunroof, Corvette Z51 Black Wheels, Black Front Fascia, aFe / PFADT Suspension Lowering Springs, Black High Rise Rear Spoiler. High flow headers, E85, Roto-Fab Cold Air, MSD Atomic AirForce Intake. aFe / PFADT Front & Rear Sway Bar. Pushing 520 to the Rear Wheels |
07-15-2020, 03:39 PM | #8 |
Drives: 2016 Camaro SS Join Date: Jan 2019
Another vote for G2. I used it back in the day with great results.
07-15-2020, 04:02 PM | #9 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
ive used spray paint for calipers and just masked with aluminum foil around the areas i wanted to paint.quick,cheap,and easy.
07-16-2020, 06:04 PM | #10 |
07-16-2020, 06:05 PM | #11 |
Drives: 2016 1ss camaro Join Date: Feb 2016
g2 paint is what i used on mine
07-16-2020, 08:42 PM | #12 |
Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
i did my 2011 calipers, used orange engine enamel from advance, added hi temp brembo decals from amazon, then clear coated with hi temp enamel. looked great years later when i traded it in (nov '19). You will need to pull the calipers to paint, I recommend paining the disk center hub and edge as well.
Ive already bought the decals for the 2019 but the originals are still new, lol.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
07-16-2020, 09:58 PM | #13 |
2020 Shadow Gray 2SS
Drives: 2020 2SS - A10, NPP, MRC, CAI Join Date: Dec 2019
I painted my rotor hubs with VHT Caliper Paint, I hated the Battleship Gray they were painted and wanted them black like my wheels..
Worked great! This part was the wife's idea!!! (How many wife's would say "Put your rotors in the oven!?!?!?!?!")
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
07-17-2020, 12:21 AM | #14 |
Drives: Fast if no one's looking Join Date: Aug 2019
I’ve used VHT for years. Probably 25 years, since I started working on cars and I just painted my calipers red. Never had a problem with it and it lasts. Highly Recommended. Just spray it in thin coats, wait about 5 min between coats, and put 3-4 coats on. Then drive the car to heat up the brakes and bake it on.
