Old 12-08-2020, 03:28 PM   #1
shinzzerz
Drives: '15 1LE
Johnson Lifter Which One ?!?
Hey Guys,
I've searched around this forum, but I couldn't get any solid info on which lifter is more suitable for a cam'd LS3 camaro. I would be going with the Johnson 21X6 reduced travel lifter (note there is also a short travel variant that is more akin to solid lifters).
I'm looking at either Johnson 2126LSR vs the Johnson 2116LSR.
The main hesitation with the 2126 (beyond price ) is that they are equipped with axle oiling which will reduce oil pressure. I was wondering if anyone here has any experience with running the 2126LSR lifter with 30 weight oil with the stock oil pump on the LS3? Did you notice an appreciable drop in oil pressure?
This is the 2126 with extra orifice for axle oiling
Thanks!
shinzzerz is offline   Reply With Quote
Old 12-08-2020, 04:44 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
i use valvoline 10w30 vr1 oil
10296 melling
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 12-08-2020, 05:02 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I have the 2116lsr. I run 5w30 Royal Purple. With Yella Terra rockers, I machined all the pedestals to allow .040 preload... the valvetrain is quiet ��
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 12-08-2020, 11:40 PM   #4
shinzzerz
Drives: '15 1LE
Thanks for all of the info I appreciate it. I think I'm going to go with the 2116LSRs. Those lifters seem to fit the bill for what I need.
