#Camaro6
AWE Tuning
Old 01-05-2021, 08:15 AM   #1
christisnt
MDRHRNT
Drives: 2019 Camaro SS Fireball Edition
Cam and D1x Power guess
Alright guys, she’s in the shop right now getting Pistons and rods, btr stage 3 supercharger cam, and Circle D 3600 stall.
I’ll also be swapping out the pulley on the D1x for the 3.85 which i’m told should make about 15 psi.
My other mods are fore innovations dual in tank fuel pump, lt4 hpfp, lt4 injectors, kooks 2” longtubes.
Right now i’m back on pump 91 octane but i may be going back on e85 if my fuel system can support it.
What are y’all’s guesses on power?
i’m praying to the good lord i can make it to 900
christisnt is offline   Reply With Quote
Old 01-05-2021, 08:22 AM   #2
Choda
Drives: Turbo 6.2
IMO, 900 wheel at 15 psi would be extremely impressive esp without meth or race gas
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 01-05-2021, 08:57 AM   #3
Puddin
Drives: 2016 Camaro 2SS
I'll say 840 because I think your high side is going to hold you back on E85.
Puddin is offline   Reply With Quote
Old 01-05-2021, 09:06 AM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
You will be out of injector and high side pump before making 900 unless you run 15.00 per gallon ms109. 91 won't be enough octane for that power and E85 will require at least FIC +30 injectors and a LPE DI pump...and even then you might need to mix it to E60. For full E85 likely will need Port Injection or XDI DI system.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 01-05-2021, 09:38 AM   #5
Osbornsm
Drives: 2018 SS 1LE
Place your bets !!!
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si
Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8
Results: 470 hp / 447 tq
Osbornsm is offline   Reply With Quote
Old 01-05-2021, 09:42 AM   #6
95 imp
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike
I give it 3 days on 91 before you turn it into a boat anchor...
95 imp is offline   Reply With Quote
Old 01-05-2021, 10:35 AM   #7
Umbriel
Drives: 2016 Camaro SS
Run out of fuel in the 700ish range.
Umbriel is offline   Reply With Quote
Old 01-05-2021, 10:55 AM   #8
christisnt
MDRHRNT
what if i run 101? they have a gas station where i live that sells it from a pump
Old 01-05-2021, 12:44 PM   #9
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
If you leave that pulley on, you’ll need to run 101 all the time. 800 wheel is about the limit on 93 octane assuming 10:1 compression and a blower cam with no overlap. So 101 will get you some wiggle room but you’ll have to change the pulley for less boost in order to run 91 octane on the street IMO. KingLT1’s post was money, as usual.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is offline   Reply With Quote
Old 01-07-2021, 07:06 AM   #10
christisnt
MDRHRNT
so do you think that i could run 93 daily and when i want to go out and race i can fill up with 101?
Old 01-07-2021, 07:41 AM   #11
Choda
Drives: Turbo 6.2
youd have to switch not only fuels, but blower pulleys and tunes.
Old 01-07-2021, 10:39 AM   #12
Joshinator99
Yep, what Choda said.
Old 01-07-2021, 04:15 PM   #13
christisnt
MDRHRNT
oh okay. i gotcha. thank you
cammed, horsepower, opinion, procharged, whp
