Old 06-23-2021, 10:33 PM   #1
michel228
Drives: Chevrolet Camaro 2013
Question Help switching radio
Hi, I would like some help and input please.
My sound system was having some problems and I found out that it was the satellite player radio. (pic that says original)
So I purchased a replacement and was told it belonged to an Equinox and was pretty much the same. (other picture)
I the proceeded to swap memories between them and it worked great, the touch screen was fine and all. However, the buttons outside the screen have switched to random places and I cannot figure it out. (third pic)
Any insight on this matter?
michel228 is offline   Reply With Quote
Old 06-24-2021, 09:25 AM   #2
pcguy2u
pcguy2u's Avatar
Drives: 2009 Corvette ZR1
Seems like that should have been a seamless swap???
Here's a link to my 70 Chevelle build thread:
https://www.chevelles.com/forums/12-...aro-donor.html
pcguy2u is offline   Reply With Quote
Old 06-24-2021, 10:13 AM   #3
Leo72793
Drives: 2011 2SS/RS
if it wasnt VIN programmed by Gen5Diy then it wont work. All Mylink infotainment systems are vin locked. Swapping isnt capable. Also, the input panel is not the same. youd need one from a camaro for proper input controls.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 06-30-2021, 09:55 AM   #4
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Is it doing anything aside from powering on?
As noted above, these are supposedly VIN locked and need to reprogrammed to function. The programming will likely also resolve the button issue.
JimE is offline   Reply With Quote
Old 06-30-2021, 12:27 PM   #5
michel228
Hi my friends,
Thank you for the attention and willingness to help.
We transferred the memory from one device to the other.
Everything works fine, except for the external side buttons that have gone crazy and switched places. Anyway to fix this?
Kind regards
Old 06-30-2021, 07:09 PM   #6
spyderbuddy
spyderbuddy's Avatar
That's the standard Bezel for the Radio without Nav
PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting an My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller, Heritage Grill, Diode Dynamics Led Lighting, Manual Shifter Boot, Paddle Shifters, CNC Throttle Body, Trifecta Tune, RX Catch Can & Breather, Trunk Black out and Side Grills, Chevorlet door Sills.
