Old 07-17-2021, 02:08 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Daetschwerks Camaro Dual Fuel Pump is finally here.
Got a notification from them yesterday. Here's a link for those that want to know. Looks like it can be bought without the pumps possibly to add your own higher flow pumps.
https://deatschwerks.com/collections...cts/9-301-7002
FasNuf is offline   Reply With Quote
Old 07-17-2021, 02:13 PM   #2
Silver14
Drives: 2014 SIM 2SS
I don’t see a link but would like to read more about it!
Silver14 is offline   Reply With Quote
Old 07-17-2021, 02:16 PM   #3
FasNuf
FasNuf's Avatar
Old 07-17-2021, 04:12 PM   #4
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
is it a drop-in plug-n-play like their first module they pulled off the shelves a couple of years ago?
Sent from my SM-G975U using Tapatalk
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 07-17-2021, 06:39 PM   #5
FasNuf
FasNuf's Avatar
I’ll make a post when I get mine. I’m sure it’s not plug n play though.
Old 07-17-2021, 07:01 PM   #6
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Return style system?
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 07-17-2021, 08:10 PM   #7
Roader
Drives: Camaro
I have the original. Hopefully they fixed all the issues
Roader is offline   Reply With Quote
Old 07-17-2021, 09:06 PM   #8
FasNuf
FasNuf's Avatar
Yes return style
Old 07-18-2021, 11:57 AM   #9
FasNuf
FasNuf's Avatar
The sales sheet
https://www.dropbox.com/s/cil7dba0m4...eid=198edc220a
and a YT video (no sound)
Old 07-25-2021, 12:59 PM   #10
jus1975
Drives: malibu maxx ss chevy ss
following
jus1975 is offline   Reply With Quote
Old 07-28-2021, 01:53 PM   #11
FasNuf
FasNuf's Avatar
I got the pump a couple days ago. Looks like quality but it is a kit and comes completely unassembled. It didn't have any instructions in the box or online so I ended up calling to have them emailed. The instructions were lacking in many areas especially on how to configure the pieces on the PRV (pressure relief valve). They also omitted the instructions about the filter socks completely. Once assembled, it looks great. I'll update once I get it installed, but it may be a while.
Old 08-16-2021, 10:54 PM   #12
FasNuf
FasNuf's Avatar
Well I got their PTFE lines kit to go along with it. P/N 6-610. Again no guide what so ever on which fittings go where. I called technical and they said he would have them emailed that afternoon that they were still finishing them up...that was 4 days ago. Nothing online. Looks like I'll be calling back to see whats up.
Old 08-17-2021, 06:41 AM   #13
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Interested in this. Please send updates once installed
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 08-17-2021, 11:13 PM   #14
FasNuf
FasNuf's Avatar
I got the install guide and really it just shows what fitting go where wether you want a dead headed fuel rail or an in series after market fuel rails setup. I took inventory and all the fittings were there and 2 that I didn't recognize. It did not show where they put the regulator or fuel filter. I guess they left that up to you to decide. Hopefully there's enough hose.
