#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
AWE Tuning
Old 11-07-2021, 09:37 PM   #1
8driann
Drives: 2012 Camaro SS 45th Anniversary
Question Headers + straight pipe = CEL?
Thinking of getting 1-7/8s headers and straight piping all the way. I did this on my 5th gen Camaro and I always had a CEL even after tuning twice. I will admit, I installed them when I was a noob and decided to make my own O2 extension with some wire laying around, which I think was my problem. I’m no expert now but I’ve definitely gained more mechanical experience, but, correct me if I’m wrong, I think wire type/gauge has something to do with voltage readings etc, which I think was my problem. Anyways, I could never get rid of that CEL and it was the p0300 code which drove me absolutely insane. Tried almost everything you can do on the surface and never got rid of it. Anyways, I was planning on doing everything right with the proper parts and no corner cutting on making parts DIY. I will be going to a muffler shop for them to weld back my exhaust after I install headers and then to a reputable tuner here in Houston. Has anyone had problems with a CEL after a similar setup?
8driann is offline   Reply With Quote
Old 11-08-2021, 01:32 AM   #2
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
You’re better off tuning out the header codes before you actually install the headers or you can end up with permanent codes in the ECM memory. Any decent tuner can facilitate that, then touch up the tune after you get them installed.
P0300 is a misfire code, not typically associated with headers.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
Joshinator99 is online now   Reply With Quote
Old 11-08-2021, 12:55 PM   #3
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
You get a CEL because the 02 location changes with your headers hence the extension being needed for them. I haven't heard any having issues where it stays on but i'm running a straight pipe up on 2 inch headers and no cats, when the car was tuned it was just a simple fix for any tuner out there to get that corrected.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
bolt on, exhaust, headers, tune
