02-26-2022, 03:08 PM | #1 |
Drives: '11 2SS/RS LS3 M6 (Sold) Join Date: Dec 2015
Puking coolant. Possible head gasket issue?
For some background, I just bought this car and I’ve been slowly changing things, fixing the shitty work, and getting it to be a nice car. Here is my problem, there are two lines that run from the radiator cap. One goes to the overflow tank and the other just vents to the atmosphere. The previous owner had stuck a bolt in the line that vents and I took it out becauseI seen no good reason for it to be in there. Long story short the car spit out all of the coolant and the car overheated before I even noticed and I had to baby it to the auto parts store to buy more coolant and another bolt to plug the line. I also bought a new radiator cap while I was there but it did not fix the issue.
Here is my question, is this line supposed to be vented to the atmosphere? It is possible that the overflow tank line and that line are switched? It doesn’t puke any coolant at idle, just when you’re giving it throttle. There is no coolant in the oil that I can see. I don’t have a leak down tester so if I can’t remedy this problem I’m just going to pull the heads. The line I’m holding in my hand in the photo is the line that is venting, the one on the other side of the cap is going to the overflow tank
2011 IOM 2SS/RS LS3 M6- Injen CAI, TSP 1 7/8” headers, PTB, Hurst short throw, Corsa catback exhaust, 20" TSW Nurburgrings, BMR lower control arms, BMR tunnel brace, Hotchkis lowering springs. 3660lbs. Tuned by me (sold)
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. |
02-26-2022, 03:36 PM | #2 |
The line closest to the top of the radiator cap should be going to the overflow tank, and the lower line is the steam line that should be hooked up to the crossover pipe at the front of the intake manifold (steel line bolted down at the front corner of each head).
02-26-2022, 03:50 PM | #3 | |
02-26-2022, 06:50 PM | #4 | |
02-27-2022, 07:08 PM | #5 |
It is definitely not in the front, possibly could be in the rear, but typically the rear crossover is blocked from the factory. If both crossovers are blocked off, that could definitely be part of your issue....
Here is a picture of where it should be.... |
02-27-2022, 09:27 PM | #6 |
I’ll check when I get the chance. Well since that line was meant to go to the steam lines then I don’t really have an issue with the coolant coming out of it. It’s supposed to. So I’m not worried about the head gaskets, I don’t have any other inclination that they are bad. Everything checks out. I just can’t understand why they would cap off the steam lines. It’s my understanding that they are pretty important in LS’s. I’m probably going to order the steam lines and try and get the plug out with an extractor so I don’t end up having to pulling the heads to get them out.
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. Last edited by WVracer; 02-27-2022 at 09:48 PM. |
02-28-2022, 04:09 PM | #7 |
376 cubic inches of fun
Cooling system 101: you have to do a pressure check of the system. If the system is not pressurized, the boiling temperature is too low and the coolant boils off. If the system is holding pressure, the boiling point is way above any temp that you would reach even racing, and there's no significant coolant loss FOR YEARS.
03-01-2022, 11:35 AM | #8 |
So after doing some digging it seems my rear steam ports have bolt on plugs and the front steam ports were plugged with the ones that are punched in. So I called Motion Raceworks and ordered one of their kits to vent the rear ports as well. I don’t plan to pull the head so I’ll be drilling the plugs out of the front ports. Should make everything good to go. I just still don’t know why they plugged them to begin with.
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. Last edited by WVracer; 03-01-2022 at 11:58 AM. |
03-01-2022, 02:42 PM | #9 | |
03-01-2022, 06:04 PM | #10 | |
2010 RJT 1SS/RS LS3 M6- CAI, TSP 2” headers, TSP F-35 cam, PTB, Hurst short throw, Dronemaster catback, BMR lowering springs, Kirkey seats, 20”/18” Weld Belmonts, 3550lbs. Last edited by WVracer; 03-01-2022 at 06:15 PM. |
03-01-2022, 06:53 PM | #11 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
goes here.........
Bone Stock |
03-02-2022, 07:00 AM | #12 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
The stock vent tubes shouldnt be too hard to find online. You'll probably be just fine capping that radiator port. Just fill the system and get the air out best you can. Heat it up, cool it down, and top it off.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
03-04-2022, 03:58 PM | #13 | |
