Old 06-01-2022, 08:22 PM   #1
Tomd27858
Drives: 2011 Camaro SS
2011 2SS Manual Shifter Improvement
I have had this Camaro for about 2 years and have put 10k on it. I have never been happy with the shifter. I did a bit of searching regarding the MGW and the Hurst shifters. I was reluctant to order one since I will be doing all of the work on my back on jack stands or ramps. I love tinkering but it just seemed like a huge pain...also it isn't a daily driver.
Anyhow, we took the ole girl out for a couple hour drive and the stiff...hard to get in 1st or 5th shifter started getting on my nerves. I had made up my mind that something had to get done. My Trans Am shifts like butter....and is 12 years older....
When I got home, I pulled the trim and the gauge cluster from around shifter to get my thoughts together. I looked at the upper boot and popped it loose. I got to thinking....maybe after 11 years things just need a little love. I took a needle oiler with synthetic oil and dripped it down the shift lever. Figured it couldn't hurt. Worked the shifter a bit and wow!....It is better.
Giggled to the wife and discussed the placebo effect that all men suffer from. She drove it up to the store to pick up a few things and shrugged her shoulders and said it did make a difference. It has been several days since I drove it. I needed to change the light bulbs in the garage so I moved the Camaro out of the way. I was like...wow! all over again. It made a huge difference. Placebo effect wore off and things were still better.
I just thought I'd share with the group. It is not a MGW shifter by any means. It is a step in the right direction though.
Blue skies!
Tomd27858 is offline   Reply With Quote
Old 06-02-2022, 12:06 AM   #2
SS376
SS376's Avatar
Drives: 2013 1SS LS3
Interesting. I put a Raceseng weighted shiftknob on mine and amazingly it made a really noticeable difference.
SS376 is offline   Reply With Quote
Old 06-02-2022, 06:08 AM   #3
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
I did the MGW in my early 40s, with jackstands. Put it in my 2010, changed it back to stock, and reinstalled it in my 2013. It's really not too bad.
chef-beavis is offline   Reply With Quote
Old 06-02-2022, 06:46 AM   #4
hesster
hesster's Avatar
Drives: '10 C5 SS, '77 Bandit T/A
I went with the Hurst Shifter and the Hurst "Pit Pack" addition. Significant improvement over stock. Then added a Raceseng Ashiko 1.6lb Shift Knob to replace the weenie Hurst ball. Better yet.
https://www.phastekperformance.com/2...gs-3326030.htm
hesster is offline   Reply With Quote
Old 06-02-2022, 07:13 AM   #5
demonspeed
not afraid of the wall
demonspeed's Avatar
Drives: Camaros
Love my MGW. I was always a Pro 5.0 guy in third and fourth gens, but MGW makes a nice piece that’s worth the money. I’m not sure how anyone could stand the sloppy, long throws of stock. Even the OE Hurst shifters are slushy. Nonetheless, if it’s an improvement for you then it’s a win.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100
Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z
demonspeed is offline   Reply With Quote
Old 06-02-2022, 08:56 AM   #6
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
I'll go ahead and be the contrarian here - I think that the stock shifter is really pretty decent. My 2011 had a aftermarket Hurst Billet Two Plus in it when I bought it - and it was junk. It was noisy, it was sloppy, but the worst part was that it really caused trouble getting the car to reliably shift when driven aggressively. I've had stick cars my whole life, and that shifter genuinely made me feel like I didn't know what I was doing.
Now, I'm aware that they make a "Pit Pack" which has a different bushing set and tightens it up a little. I'd contend that they ought to just sell it that way, knowing how problematic it is. Dollars and cents I'm sure driving those decisions. I can imagine that with good bushings and a heavier ball it probably could be decent - but that wasn't my experience at all.
I tried a different master cylinder, bleeding the clutch, running Redline D4 ATF, but what cured my poor shifting was simply getting my hands on an OEM shifter and swapping that in. Instantly resolved every problem I had with the trans. So, I have little love for the aftermarket Hurst.
The stock shifter has been just fine. I think an MGW would potentially be an upgrade, but not a substantial one. Maybe for a circuit raced car the stronger centering would be more important to me, but my car primarily sees drag, and the stock shift has been plenty adequate. Sounds like the original poster has found much the same.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-02-2022, 09:35 AM   #7
demonspeed
demonspeed's Avatar
Drives: Camaros
Andrew, Hurst shifters suck. Period. They’re only popular due to the nostalgia factor. I’ve been into drag racing for two decades and a shorter, quicker, tighter shifter is one of the best mods - and one of the first - I’ve always done. If we were closer I’d be more than happy to let you abuse mine to prove it
10/13/22: 1100
Old 06-02-2022, 09:36 AM   #8
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
Is it just me, or is the shift pattern on the knob different than the one on the bezel?
I ordered my 13 2ss with only 2 options.....NPP and the Hurst shifter. Had I known about the 1LE that box would have been checked also! Anyhow I'm very happy with the factory Hurst shifter.
NOT A 45 is offline   Reply With Quote
Old 06-02-2022, 09:47 AM   #9
acammer
acammer's Avatar
I've driven a few MGW cars, C5Z06, couple 5th gens. I definitely don't dislike it, crisp and short is nice, but in my experience, the trans and clutch release by far more limiting factors than the shifter, especially the early 2010-2011 Camaro TR6060s - they kinda suck!
Old 06-02-2022, 09:56 AM   #10
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
Try Amsoil Manual Synchromesh Transmission Fluid.
https://www.amsoil.com/p/manual-sync...uid-5w-30-mtf/
Free Trade is not Fair Trade
I am, we are INDIVISIBLE
Invictus, By William Ernest Henley
mickss is offline   Reply With Quote
Old 06-02-2022, 10:30 AM   #11
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
I've had the Hurst Billet shifter in my SS since I got it in 2009. Quick shifts, doesn't rattle and I like it for the nostalgia. It now has 71K miles on it.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
Old 06-02-2022, 10:52 AM   #12
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
I have the hurst, put it in about 5 or 6 years ago. I dont dislike it per say but every few months i get the itch to maybe order an MGW
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads
Arogg is offline   Reply With Quote
Old 06-02-2022, 02:35 PM   #13
demonspeed
demonspeed's Avatar
Drives: Camaros
Everyone has their own technique, so perhaps that throw works perfect for your shifting and pedal modulation. It’s all in the hips, it’s all in the hips…
10/13/22: 1100
Old 06-02-2022, 04:35 PM   #14
acammer
acammer's Avatar
For sure - she loves the hip action!
