Old 01-14-2010, 03:45 PM   #1
ROD1
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09
Cat Legalities?
I live here in NY. If I remove the existing cats and replace them with high flows, will I be able to get an approved inspection?
ROD1 is offline   Reply With Quote
Old 01-14-2010, 03:56 PM   #2
lcmc
Drives: 1987 IROC Z convertible
From what I understand it is illegal to replace the cats unless the old ones are bad.
lcmc is offline   Reply With Quote
Old 01-14-2010, 04:01 PM   #3
ROD1
Retired
Thats what Ive read but peeps are doin it and I wonder how they get away with it.
Old 01-14-2010, 04:09 PM   #4
SButler
SoCal C5 Family Member
Drives: 2LT/RS CGM
The high flow cats will probably pass the emissions test. In Ca the inspector does a visual test and if they notice that they are replaced cats they can fail it unless you can prove the original cats were bad. I'm not sure if NY does a visual...
SButler is offline   Reply With Quote
Old 01-14-2010, 04:10 PM   #5
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
"legally", no, it's NOT legal to swap your cats to hi-flow versions.
That being said...how are inspections done in your county??? Do they just plug in your computer? If so, as long as your check engine light isn't on...your fine. (some counties have a tailpipe sensor to measure emissions, which you'd probably still pass anyway).
They are supposed to do a visual check to make sure all the equipment is in place...I've NEVER seen them check, and if they did, as long as they see cats there...you have no worries. The biggest issue is that your CEL isn't on.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 01-14-2010, 08:56 PM   #6
fastal
Drives: 2010 2SS/RS, 2000 Z28
Honest Officer both cats went bad and these aftermarket ones were the only ones available! It was really weird that both got ball peen hammer sized holes in them at the same time!
fastal is offline   Reply With Quote
Old 01-15-2010, 09:41 AM   #7
ROD1
Retired
OK, How bout this. Anyone here been denied inspection after doing this?
Old 01-15-2010, 05:57 PM   #8
Agent Atomic Orange
Agent Atomic Orange's Avatar
Drives: 2010 Camaro LS IOM M6
I do not know about NY, but in GA you do not have to get emmisions tested untill the car is about 5 years old. I have heard several say they will just enjoy their hi flow cats untill 2015 rolls around and then worry about it.
Airaid CAI (V2 Tube)/ Flowmaster American Thunder/ Barton Shifter Kit/ Hotchkis Sport Sway Bars/ Hotchkis Sport Springs/ AAC Lights/ GM Trim Kit/ Tint/ Pioneer Premier Champion Series Sub/ Pioneer 1500 Watt Amp
Agent Atomic Orange is offline   Reply With Quote
Cat Issue :) Dwaynelo 5th Gen Camaro SS LS LT General Discussions 9 01-06-2010 11:54 PM
My neighbor's cat better beware when the Camaro arrives! topgun1 5th Gen Camaro SS LS LT General Discussions 42 07-10-2009 10:00 PM
Headers or Cat back? H & E Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 31 07-01-2009 01:26 PM
My cat had to be put down today Dave McFly Off-topic Discussions 18 01-12-2009 05:45 PM
Cat pulls a fast one on firefighters KILLER74Z28 Off-topic Discussions 10 02-16-2008 12:00 PM
