Old 12-07-2022, 02:24 PM   #1
loufontana4
Drives: Camaro SS
Chevrolet Performance Shifter Ball
GM Part #19301623. This is the Black Chevrolet Performance Shifter Ball kit. Does anyone know if this will fit on a Hurst Shifter.
loufontana4 is offline   Reply With Quote
Old 12-08-2022, 09:09 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You would need to know the size of the inserts that come with it. My Hurst stick takes a 3/8ths insert which is pretty common.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes.
Old 12-08-2022, 03:05 PM   #3
SS_Dave
SS_Dave's Avatar
Drives: Chevrolet Camaro SS
From Summit Racing site...
LOUIS · 4 days ago
Chevrolet Performance Shift Knobs 19301623
Will this fit a Hurst Shifter.
1
answer
Answer this Question
AR · 3 days ago
Currently the Chevrolet Performance Shift Knobs 19301623 Shift Knobs do not list fitment for a hurst shifter and will require test fitting with the included adapters. We do offer other shift knobs that will work with a Hurst shift like Hurst Classic Shift Knobs 1631401
SS_Dave is offline   Reply With Quote
Old 12-08-2022, 03:09 PM   #4
SS_Dave
SS_Dave's Avatar
I am curious if this fits the standard 5th gen shifter. Was thinking it's a pop off. I would like a new ball like this now and be able to keep when I go MGW later.
Old 12-10-2022, 08:15 AM   #5
CamaroCracka
Stock shifter is push on. A shift ball with inserts would not work. You can thread the stock shifter shaft and then use a handle that takes inserts. There used to be a DIY on it and I did it about 10 years ago. Worked fine, but then I came across a cheap Barton short throw and changed it out again.
Old 12-10-2022, 12:26 PM   #6
Whitey 22lr
Whitey 22lr's Avatar
Drives: 2010 SS/RS Black, MT
Look here
I believe this is my original post where I
threaded the original shifter, about 10 years ago
http://www.camaro5.com/forums/showthread.php?t=154016
Whitey 22lr is offline   Reply With Quote
Old 12-10-2022, 05:57 PM   #7
SS_Dave
SS_Dave's Avatar
Ok, that is cool. Hadn't thought of doing it. Actually, what I want is to put a new ball on now with stock shifter. Then later when I'm ready to do clutch, do an MGW and keep the ball. Seems like this would let me do it. Thanks!
Old 12-10-2022, 06:14 PM   #8
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I made this that leaves the stock shifter rod as is. Slides over the shaft and is secured with set scews.
Adapter
0stones0 is offline   Reply With Quote
Old 12-10-2022, 06:33 PM   #9
SS_Dave
SS_Dave's Avatar
Adapter
So you're saying you'd like to make me one of those beauties?
Old 12-10-2022, 09:40 PM   #10
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
It looks nice but not $120 worth of nice. Wow.
"Never cough into a full ashtray."
Danial is offline   Reply With Quote
Old 12-15-2022, 11:49 AM   #11
0stones0
It don’t come easy.
0stones0's Avatar
Sorry for the belated reply. Just now saw your post. Happily, Im semi-retired but, because of that, I don’t get anywhere near the time on the lathe to do this sort of stuff. Otherwise, I’d probably entertain the thought.
