12-07-2022, 08:57 PM | #1 |
Drives: 2008 z06 corvette 2022 ZL1 1LE Join Date: Aug 2020
Do they ship zl1 1les in the winter?
As the title says does anyone know if they ship 1LE’s in the winter? More specific zl1 1LE’s?
12-07-2022, 08:59 PM | #2 |
Drives: 21 ZL1 Join Date: Feb 2022
Why wouldnt they? They are not towing the trailer with them on it with a ZL1 1LE.
12-07-2022, 09:24 PM | #3 |
Drives: 1969 Z28,1992 Z28,1994 Z28,1999 SS Join Date: Oct 2021
3R tires and temps below 40 degrees. Those are two reasons to question winter deliveries.
24 2SS 1LE, Riptide Blue, A10, PDR. Picked up 11/5/23, 560 miles.
23 ZLE Rapid Blue, M6. 6/27/22 TPW. Off assembly line on July 12th, 2022. To Dealer August 6th. Delivered August 8th. 129 miles. 99 SS Vert, Hugger Orange, A4, 806 miles 94 Z28, Black, M6, 595 miles 92 Z28, last car built at Van Nuys Plant, Red, A4, 125 miles www.last1992camaro.com 69 Z28, Dusk Blue, M4 29 Ford Business Coupe 28 Ford Pickup 24 GMC Denali 2500HD CCSB 4x4 22 Jeep Grand Cherokee 13 Ford F150 Crew Cab 4x4 |
12-07-2022, 09:28 PM | #4 |
12-07-2022, 09:32 PM | #5 |
I’m fully aware of that. Are you familiar with 3R tires? My local dealer had a car with 3R tires throw the rubber off them in a 100 yard drive from the transport truck to their shop. 4 new tires fixed that.
12-07-2022, 09:40 PM | #6 |
Not suppose to store or move the tires in the cold due to them cracking. So still have to move the cars onto the transporter risking cracking the tires. Just didn’t know if anyone’s 1LE was delivered in winter in colder regions.
12-07-2022, 09:43 PM | #7 |
None of the tires are cracking. Where the hell did you hear that? Sure they are roller skates when it gets cold, but cracking? Seriously man fact check yourself.
12-07-2022, 09:44 PM | #8 | |
12-07-2022, 09:46 PM | #9 |
You must live under a rock if you don’t know about 3R’s cracking in the cold.
12-07-2022, 09:54 PM | #10 | |
Note:*Tires exposed to temperatures of 20 degrees F (-7 degrees C) or lower must be permitted to gradually return to temperatures of at least 40 degrees F (5 degrees C) for at least 24 hours before they are flexed in any manner, such as by adjusting inflation pressures, mounting them on wheels, or using them to support, roll or drive a vehicle. Flexing of the specialized rubber compounds used in Extreme Performance Summer tires during cold-weather use can result in irreversible compound cracking. Compound cracking occurs as the result of improper use or storage, and Goodyear's warranty specifically excludes tires exhibiting this condition from coverage. Any tires exhibiting compound cracking must be replaced. Are you still so sure of yourself, Mr. expert?
12-07-2022, 10:02 PM | #11 | |
12-07-2022, 10:05 PM | #12 |
Look yourself if you don’t believe it. Buy a set and drive them at Zero degrees……. Good Luck!
12-07-2022, 10:10 PM | #13 |
Brand new ZLE, fresh off a load:
12-08-2022, 05:44 AM | #14 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
It's in the owner's manual
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
