#Camaro6
Go Back   CAMARO6 > Specific Packages / Variants > 6th gen Camaro 1LE
Old 03-09-2023, 12:48 PM   #1
ShmRocc
ShmRocc
ShmRocc's Avatar
Drives: 2010 Synergy Edition
Post Camaro Constraint Allocation March 9th
March 9th Chevy Camaro Constraint update ⬆️:
For customers that have orders at your local dealership for 2023 hope this information helps you get your order pushed through! We all know that the micro chip shortage is still playing a huge role in the amount of vehicles that can get built from #GM! ok here we go and all this information is for Target Production Periods (TPP) of 10-April-2023:
1: 23 Camaro Coupe ZL1 with the 1LE Track package 📦 has a National Allocation Quantity of 3% for the model year due to supplier restrictions (aka Carbon Fiber I believe)
2. 23 Camaro Coupe ZL1 without A1Z Extreme Track package 📦 has a National allocation quantity of 17% for the whole country for the rest of the model year! So this means chances are better of getting a ZL1 without the 1LE package are higher than with it.
3. If you have a Camaro order with the (WBL) Redline Edition with Shark 🦈 skin Metallic exterior that package is on constraint until April at 15% of National allocation quantity!
4. If you have a Camaro with (57V 20” Caliente Wheels) that is a model year constraint at 30% of National allocation quantity!
5. If you have a 23 Camaro order 1LT/2LT with the LGX V6 Engine there is a material constraint for the model year at only 5% of Marino allocation quantity! So more 2.0L turbo cars are getting built then V6 engines at this time!
6 and 7. If you have a 23 Camaro 3LT order at your local dealership due to material restrictions it will be harder to get as only 5% of National allocation quantity is left for the model year! And only 5% of that will be allocated with the 3LT with LGX Engine!
8. 23 Camaro 1LZ and 1SS orders due to material restrictions is at a 20% of National allocation quantity so better chances to get that LT1 and 1SS trim levels over the lower trims!
9. 23 Camaro 2SS due to material restrictions has a 20% of National allocation constraints for the model year!
10. Last but not least 23 Camaro orders 1LS/1LT/2LT/3LT with MXO Automatic Transmission without LGX engine so 2.0 turbo has a 25% of National Allocation Quantity!
Hope this helps with Camaro customers out there and any questions or comments feel free to ask or leave down below!
ShmRocc
2010 Synergy Edition 1LT 3.6L V6 with Volant Cold Air Induction and MRT v2 Axle Back exhaust, AAC Oracle Halos & Fogs, Afterburner, Max LED Underglow, footweels lighting, green dome lighting, camaro door sills, and carbon fiber bowties & side gills!
ShmRocc is offline   Reply With Quote
Old 03-09-2023, 12:51 PM   #2
ShmRocc
ShmRocc
ShmRocc's Avatar
Post Colors Ending
New 2023 #Chevy #Camaro Information ℹ️ as of Feb 23-2023. Model Constraints update!
Two exterior colors will be disappearing after the 23 model year! If you want a Rapid Blue (LPO code: GMO) the build out date is 5/18/2023 which means your order needs to be in by that time as last production week is 7/03/2023! Next Color to go is Shadow Gray Metallic (LPO code: GJI) build out date is 6/8/23 with the last production week being 7/17/23. If you have orders at your local dealership make sure they get you an allocation before hand so you are locked in for your fav. color! This is for both coupe and convertible 23 model year CAMARO’s
ShmRocc
23 camaro orders, allocation, allocations, camaro order, camaro orders
