02-05-2024, 07:22 PM | #1 |
jfkheat
Drives: 2023 Rapid Blue ZL1 Join Date: Nov 2023
Rear Differential Gear Oil?
I need to change the rear axle fluid in my 2023 ZL1. I looked in the manual to see what Chevy recommends but it just says See Your Dealer. What AC Delco gear oil should I use? If I have my local mechanic change it will it effect my warranty as long as I document it?
02-05-2024, 08:02 PM | #2 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
The 10-4034 AC Delco Limited slip gear oil is what I’ve used. You’ll need 2 qts, but it only takes about 1.5 to change it.
02-05-2024, 08:24 PM | #3 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The ZL1 and 1LE electronic differential do not require limited slip oil or additive as the clutches are controlled by a separate ATF hydraulic circuit, that said it will not hurt anything. Mobil1, Redline, AMSOIL or AC Delco will get the job done.
02-05-2024, 09:52 PM | #4 |
Drives: '21 ZLE A10 Join Date: May 2012
use the correct GM fluid which is readily available and yes it has the proper limited slip friction modifier. It is an E-diff and the tranny fluid is used in the cooling circuit of the differential...definitely not for "hydraulics".
02-05-2024, 11:27 PM | #5 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
02-06-2024, 08:12 AM | #6 |
Thank you Al Oppenheiser!
Drives: Red Hot A10 ZL1 Convertible Join Date: Jun 2017
02-06-2024, 10:20 AM | #7 |
Drives: 2016 1ss camaro Join Date: Feb 2016
ive used the oem gm stuff for years but recently just swapped over to the torco stuff not sure if ill see a difference but its a better quality oil and made in usa
02-06-2024, 10:51 AM | #8 |
Drives: 2023 SS 1LE Sharkskin Join Date: Jun 2023
I've used the oem fluid pictured above to do two oil changes so far (500/1500 miles). I would love to use a full synthetic fluid like Red Line, but I've read complaints about groaning and other diff noises when people use fluids other than oem. I understand the Delco fluid is not even synthetic, so I wonder what's so special about it?
02-06-2024, 05:29 PM | #9 |
I've used the oem fluid pictured above to do two oil changes so far (500/1500 miles). I would love to use a full synthetic fluid like Red Line, but I've read complaints about groaning and other diff noises when people use fluids other than oem. I understand the Delco fluid is not even synthetic, so I wonder what's so special about it?[/QUOTE]
A standard SS has a limited slip differential, the clutch pack is held under a static spring pressure at all times and the clutch will allow the axles to rotate at different rates after it overcomes the friction coefficient. Using a non limited slip oil can result in chatter and groaning as the discs drag during cornering, LSD additive makes the fluid slipperier and less likely to chatter . The E-Diff has computer controlled hydraulic circuit that controls the force on a clutch pack (looks like a motorcycle wet clutch), it can vary from 1 to 100% lock up according to driving conditions and sensor feedback, there is little to no friction on the clutches unless the BCM commands it so friction modifiers are not necessary. The OEM fluid is not a synthetic as you stated, not a bad thing but there are better oils out there. As stated using a LSD oil will cause no harm it is not necessary opening up more more options. A conventional LSD as equipped in the SS will not be harmed by a non LSD oil, the additive can be added if the diff experiences noise/chattering issues, products such as Redline and AMSOIL it is sold ā la carte as most LSD vehicles will respond fine to synthetic non LSD oil. My LE has 40K on it now and I've been using Mobil1 DELVAC 75W-90 synthetic to good effect. This the Corvette but is pretty much how the E-Diff functions in our cars also. https://youtu.be/k1j6ZzWXRMw Last edited by Warrior102; 02-07-2024 at 03:47 AM. Reason: Add content |
02-06-2024, 05:34 PM | #10 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
It’s only 2 quarts, just stick with the factory stuff. The modifier is not a hinder in anyway if it doesn’t require it.
02-06-2024, 07:39 PM | #11 |
jfkheat
Thanks for the responses. I ordered 2 quarts of the AC Delco 10-4034 today.
02-07-2024, 10:58 AM | #12 |
Petro-sexual
I've changed the diff' oil 3-times (at least than 4000-miles on the odometer), and used the leftover diff' oil to "flush" the old oil out (another Member posted this idea, which I liked and do). I've never had an issue with this oil, and with as stiff as my bars are, I've hung a rear tire off the ground, while stopped, and accelerated (not aggressively - just normally) into traffic, and the diff' grabbed normally and naturally, and there was no noise or anything like that. It just locked, and the car moved out.
I think Amsoil has a diff' fluid, too.
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
02-11-2024, 12:55 PM | #13 | |
jfkheat
Thanks, James |
02-11-2024, 01:34 PM | #14 |
