06-28-2010, 05:10 PM | #1 |
Axle Back & Cat Back
What the difference between cat back and axle back exhaust systems? I want to upgrade at some point and realized that I don't really know what the difference is.
Is there an inherent benefit of one over the other? Thanks!
2010 1LT A6 Cyber Gray Metallic
Injen CAI - Barton Shifter "Made from 100% Awesome" |
06-28-2010, 05:13 PM | #2 | |
v It bites.
Drives: 2011 IBM 2SS/RS Join Date: May 2008
I personally only plan to do a cold air intake and exhaust. So I went axle back, cheaper, relatively same exhaust note....Generally Axle back is much cheaper.
2011 2SS/RS
Performance: 439 RWHP: 226/236 Comp Cam, Kooks 1-7/8, CAInc, Borla S type, Vmax TB, Rx Catch Can, Trans cooler, SLP 160 termo, Melling high volume, Eibach Springs/Sways 1" drop, Whiteline complete bushing kit. |
06-28-2010, 05:41 PM | #3 |
Whats a Millwright?
Drives: 2LT/RS SIM, 05 Wht Denali Join Date: Feb 2010
You typically get better gains from cat back systems. If you are after that little bit extra for the strip the cat back is the way to go. If you just want a little better sound than stock you need to shop around for axle back, which are less exspensive.
Similar Threads | ||||
magnaflow 3" comp series cat back | GQ4Life | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 32 | 01-20-2010 01:57 PM |
Cat Back Exhaust Question? | Paul4137 | V8 Bolt-Ons & Tunes | 4 | 10-31-2009 10:05 PM |
L/T with off road pipes or a good cat back ?? | LSU/LS3 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 4 | 10-19-2009 09:12 PM |
Does an axle back have the same problems as a cat back? | G.E. | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 09-15-2009 03:31 PM |
Cat back or axle back? | norcalwheelman | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 2 | 07-22-2009 08:15 AM |
