Old 07-26-2010, 06:12 PM   #1
grip750
grip750's Avatar
Drives: 2SS Victory Red
? about lowering with springs
I was just about to order H&R Springs (1.4" drop in the front and 1.3" in the rear) I was on H&R's site last night and saw that they have another option with a new set of springs that would drop the car 1.8" front and 1.7" in the rear. I called them today and asked about the new springs and testing that was done on them, they said they were approved for sale. What do you guys think? Is that too low for this car and would the ride suffer?
Thanks
grip750 is offline   Reply With Quote
Old 07-26-2010, 06:14 PM   #2
GuidosCamaroSS
Drives: 2010 Black Camaro SS/RS MTX
Might as well just dig a grave now for your stock dampers.
GuidosCamaroSS is offline   Reply With Quote
Old 07-26-2010, 06:18 PM   #3
grip750
grip750's Avatar
So that would be a no
But their internet site says it has great ride quality lol
Old 07-26-2010, 06:42 PM   #4
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Great is relative.
That's a hell of a drop. The rear I think would look and work great. It will limit some options on the front maybe. If I were gonna go that low, I'd do coilovers.
Old 07-26-2010, 07:01 PM   #5
Info@PeddersUSA.com
Info@PeddersUSA.com's Avatar
Drives: 5th Gen Rental
Our testing shows you should stick to their 1 inch drop area. That will be a lot less stress on the damper, and give you a better quality ride.
mike
Info@PeddersUSA.com is offline   Reply With Quote
Old 07-27-2010, 11:29 AM   #6
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
That is an excessive drop with stock springs. When developing our springs we found that more than 1.4" and the car ran out of alignment adjustment. It also puts the OE shocks beyond their damping range so not only will your ride suffer but handling as well. If you need to go lower than 1.4" I would get a set of coil-overs such as the KW Variant 1 or Variant 3's.
Full line of 2010 Camaro parts HERE:
http://www.bmrfabrication.com/F5.htm
BMR guy is offline   Reply With Quote
Old 07-27-2010, 02:38 PM   #7
Info@PeddersUSA.com
I do not think you have posted what you would like your drop to be and your goals. Have you made a decision on this?
thanks
mike
Old 07-27-2010, 02:49 PM   #8
seddon
seddon's Avatar
Drives: 2017 ZL1
Thanks
That mush drop will kill your factory dampening. If you are just doing springs stick to a 1" drop. The H&R's I had were great and dropped about 1.25" all around. If you want a greater drop than that I would go for coils. Pedders, pfadt, or Kw's are all great, pick within your budget.
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
seddon is offline   Reply With Quote
Old 07-27-2010, 02:53 PM   #9
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Going that low will not only end your stock dampers but you will be in for one bouncey ride. Pfadt lowering springs are design for a 1-1.25 inch drop specifically because this is the optimum ride height for Camaros running stock dampers, go any lower and things get nasty. If you want more you should look into coil overs.
H&R Sport Lowering Springs IN STOCK NOW!! AJ@ECSMotorsports Suspension / Chassis / Brakes 25 10-13-2010 10:35 AM
BMR Lowering Springs - How It's Made BMR Suspension Suspension / Brakes / Chassis 40 06-22-2010 10:32 AM
Eibach Lowering Springs & Sway Bars @ Phastek Performance Jason@Phastek Suspension / Chassis / Brakes 0 01-29-2010 03:56 PM
