08-01-2010, 10:08 AM | #1 |
Drives: 1987 IROC-Z 305 TPI 700R4 Join Date: Jul 2010
removing dents with hairdryer and ice.
anyone tried this? Does it work? i tried it a bit ago but i didnt do to good of a job at it, going set the car in the sun, heat up the dent a bit with a hair dryer and get some really cold ice on it. also has anyone used one of the dent pullers from like harbor freight?
What is a Camaro? A small, vicious animal that eats Mustangs.
Me -14! year old guy -- My Girl -1987 IROC-Z 305TPI 700R4 modded |
08-01-2010, 10:10 AM | #2 | |
GM Employee
Drives: 2010 Camaro SS/RS Join Date: Aug 2009
2010 Camaro SS/RS - Doug Thorley LT's, SNL V.X Cam/Tune, ADM Cold Air Intake, GMPP Exhaust
08-01-2010, 10:12 AM | #3 |
Boomer Sooner
Drives: 2010 Camaro 2SS/RS SIM Join Date: Aug 2009
its dry ice that works the best. the sun will do it sometimes on smaller dents and a dark color. i personally would find a good pdr guy and let them do it.
SIM 2SS/RS, Tinted lights, Halltech CAI, Heritage grille, Borla ATAK axle back, Showstopper LED mirrors, AACstyle Illuminated LED Rear bowtie, KITT mail slot scanner
http://www.lubedealer.com/simplysynthetics |
08-01-2010, 10:18 AM | #4 |
I used pops a dent for mine, and those will help in pulling the dent.
I tried the heat then ice method, and there was no luck with that. I didn't try dry ice.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
08-01-2010, 10:18 AM | #5 |
im going try the regular ice now i think, then if that doesnt work the duster (would a air compressor work?) and if that doesnt work maybe dry ice, where do i find it?
08-01-2010, 10:23 AM | #6 |
i also tried pops a dent I HATED IT! i used the glue like your suppose to but it still melted onto my paint and i scraped what i could off but theres still a bit on the fender.
08-01-2010, 10:24 AM | #7 |
Boomer Sooner
a air compressor will not work, basically you are trying to massage the metal back from having a stretch in it. the methods being mentioned are trying to bring extreme temperature change to the metal to allow it to pop back. the suction cups will work, i have even used a new/clean toilet plunger. the main thing with the suction cups, etc is lubricating the metal so you don't scratch it with the dry cup. just spray some soapy water on it and you will be fine. if that doesn't work a good pdr guy can take it out.
08-01-2010, 10:24 AM | #8 |
GM Employee
no a air compressor wont work the air that hits the panel has to be ice cold for it to work
08-01-2010, 10:26 AM | #9 |
Dry ice is frozen CO2 so it's essentially the can of air duster but colder (because it's forzen not liquid) and harder to handle. I would try the upsidedown air duster. If it doesn't work the dry ice probably won't work much better. Just heat it up good. (don't burn the paint!) Then quickly blast it with the duster upsidedown until you get a result. This will probably only work on dents that are like small circles if you have a crease it will be less likely to work. Compressed air will not work.
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
08-01-2010, 10:28 AM | #10 |
thanks guys
i figured an air compressor wouldnt work but i thought maybe there was a way to let it shoot out ice cold air. is there anywhere else to buy suction cups instead of online, wont be able to get one online as we have never felt to safe doing that.
08-01-2010, 10:31 AM | #11 | |
It sounds like you had the glue too hot.
08-01-2010, 11:03 AM | #12 |
Check out Home Depot or Lowes. Heck even a good small plunger would help. as long as it makes a good seal.
08-01-2010, 11:25 AM | #13 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
I used the duster and heater method on my 2006 charger. I had a door ding - more of dent than a ding really. If the metal was "stretched" or creased then forget about using any method above. If the metal was simply bent like mine was it works pretty good.
I don't recall all the tricks. But heat the area with a heat gun or ( worse case ) hair dryer. Make sure the center is the dent and that it is the hottest work in a circle pattern to het the area around the dent. Turn the duster can upside down and spray the liquid onto the pnel in a circular motion starting on the outside and working toward the center. You should be able to watch the metal moving toward you. I did process like three times and the dent was almost gone but a lot less noticeable.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
